MiniMe Rev Limit? - D-series.org
Old 04-23-2013, 01:00 PM   #1 (permalink)
strykr's Avatar
Rep Power: 0 strykr is nobody
Default MiniMe Rev Limit?
Hey guys, I think I have narrowed down my smoking issue to the headgasket or IM gasket. I have been wanting to do a minime swap with my D15B7 block and a Z6 head so I may as well do it while im changing the head gasket.
My question is what do you guys think the max useable rev limit I should go for the minime setup? I have a moates demon on a chipped P06 ecu and will be tuning with Neptune.
1995 EJ2 D15B7 I/H/E Planned: Minime | Rear Disk | Coilovers | Turbo
2010 Genesis Coupe 2.0T | WHP: 300 @ 20Psi
'92 DA B16A SiRII & Y1 LSD - Sold
'94 DC4 - Wreckers
strykr is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 01:03 PM   #2 (permalink)
rico58204's Avatar
Rep Power: 18 rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!rico58204 is the fucking MAN!!!!
Wherever it stops making power without floating your valves. If it is a stock z6 head, I wouldn't go over 7500ish.
Can you provide instructions on how to wire all 4 vtec solenoids in parallel? I would like to hit vtec 4 times as hard, but I'm confused as to how the wiring configuration would look. Thanks
You link all the grounds, then wire each solenoid into the spark plug wires, that way they hit sequentially as the engine fires. This creates what I like to call asphalt shattering VTEC.
rico58204 is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 01:14 PM   #3 (permalink)
strykr's Avatar
Ya I understand the floating valve part, seems like 7500-7700rpm would be a good area to put the limit but just want to see what anyone else has gone to safely. Just not sure what the bottom end can handle (since I think there's no oil squirters?)
'94 DC4 - Wreckers
Old 04-23-2013, 01:25 PM   #4 (permalink)
Rep Power: 0 gsrteg83 is nobody
i've rapped my little jdm d15bv to 7500 a few times it holds together no valve float but i wouldnt do it all the time. also with the d15b7 there are no oil squirters so i am thinking 7000 to 7200 tops. unless you dont want that engine to hold together long.
gsrteg83 is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 01:29 PM   #5 (permalink)
BiggieBert's Avatar
Rep Power: 22 BiggieBert Still a JDM Star....
BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....
iTrader Score: 12 reviews
if stock internals, 7200 I would say.
you will get stuck in the "willfully ignorant" category and I will do what I can to see that you never get an answer to any question you ever ask on this forum again.
BiggieBert is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 01:32 PM   #6 (permalink)
rico58204's Avatar
You have a 1.58 r/s ratio with the d15b7. The z6 is 1.52. Not much difference. Your head will decide your rev limit.
Old 04-23-2013, 01:40 PM   #7 (permalink)
strykr's Avatar
But the D16Z6 has oil squirters, which make a big difference for high revving.
'94 DC4 - Wreckers
Old 04-23-2013, 02:08 PM   #8 (permalink)
BiggieBert's Avatar
I dnt remember oil squirters in my z6
Old 04-23-2013, 02:32 PM   #9 (permalink)
79hilux90crx's Avatar
Rep Power: 19 79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....79hilux90crx Still a JDM Star....
9,000!!!!
93 Ford F150 4.9 Back up/Work Truck
95 Chevy S10 2.2 Dad's Old Truck Project
07 V-Star 650 The Bike
98 Jeep Cherokee 4" Lift Cut Fenders 33x12.50 Daily/Offroad Toy
79hilux90crx is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 02:38 PM   #10 (permalink)
shoebox_civic's Avatar
Rep Power: 24 shoebox_civic Still a JDM Star....
shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....shoebox_civic Still a JDM Star....
that's because they're not there
99 CRV
02 S2000 - Pioneer MVH-X560BT, Alpine KTP445U, FIPK
15 Accord Sport 6MT
90 Skyline GT-R - HKS Drager exhaust, Pioneer DEH-X8700BS, PPI i640.5, Infinity 1262w, Alpine Type-S
Old 04-23-2013, 02:41 PM   #11 (permalink)
strykr's Avatar
I couldve sworn they did, my bad.
'94 DC4 - Wreckers
Old 04-23-2013, 05:47 PM   #12 (permalink)
maohonda's Avatar
Rep Power: 7 maohonda  is slowly gaining respectmaohonda  is slowly gaining respectmaohonda  is slowly gaining respectmaohonda  is slowly gaining respectmaohonda  is slowly gaining respect
I have takeing my d15b7 y7 mini me up to 7500 a many a time with the Itbs but now its boosted so I only go to 7000 to make the rods hold together. lol. I also have arp rod bolts and crower spring and ti retainers. If you don't have the rod bolts, after a short while the stock bolts will stretch causing engine failure. Trust me mine started to do it but i caught it in time before it hurt itself. Installed the rod bolts and some seal power bearing in the car and it still running real strong today with about 50k on the engine and 15k of that on boost 7psi
As for power up that high It will love to rev there in the lower gears but with my set up the power started falling off a little after 6500. it more or less leveled off.
maohonda is offline   Reply With Quote Quick reply to this message
Old 04-23-2013, 06:19 PM   #13 (permalink)
The_Acid_Beaver's Avatar
Even if it did, oil squirters are not so much for high revving as for cooling hot pistons and actually can spray so much oil that you lessen the engine's acceleration.
RTFM. No, really. Do it.
Old 04-23-2013, 07:30 PM   #14 (permalink)
JaredKaragen's Avatar
Rep Power: 15 JaredKaragen is almost there....
JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....JaredKaragen is almost there....
my only commwnt on this topic:
oem sohc valvesprings are only good to 7.5-8k, this is where valves start to float. anyone claiming more is full of crap or has a miscalibrated tach
SF bay area tuner, mechanic, and engine builder.
*Signup Required*
1995 DelSol Si : B18C1/I/H/E Totalled. Swap is sold. Soon to part out.
Pat: You will be remembered.
JaredKaragen is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 04:11 PM. | Welcome to Forum, please register to access all of our features.
