mtx-l help - D-series.org
Old 08-16-2012, 03:35 PM   #1 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 40 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
Send a message via AIM to sleepingciv Send a message via MSN to sleepingciv Send a message via Yahoo to sleepingciv
Default mtx-l help
ok got my wideband in today got it in the car went by the instructions calibrated it like it says to ect ect.
hook it all up ect ect
start the car and get error 9. so i find it has low voltage. no biggie i fix that problem. start the car again and the gauge is reading 22.XX maxed out pretty much.
you think i should pull the sensor and recalibrate it or you think cause the tune is so far off??
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 03:43 PM   #2 (permalink)
BiggieBert's Avatar
Rep Power: 22 BiggieBert Still a JDM Star....
BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....
iTrader Score: 12 reviews
I would recalibrate and if it doesnt fix check your wiring again.
you will get stuck in the "willfully ignorant" category and I will do what I can to see that you never get an answer to any question you ever ask on this forum again.
BiggieBert is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 03:46 PM   #3 (permalink)
ya prob have to
as for the wiring it cant be wrong its all plug and play and 1 ground and 1 positive wire lol.
PM me for
Old 08-16-2012, 03:50 PM   #4 (permalink)
19si91's Avatar
Rep Power: 12 19si91 is hot as a volcano19si91 is hot as a volcano
19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano19si91 is hot as a volcano
iTrader Score: 15 reviews
the white wire is for your headlights to dim it at night. If you do not use that feauture hook it to a ground. I believe it needs to be grounded as well. But as stated above recalibrate and check wiring. I dont know if that white wire would affect your readings but i know innovate say it needs to be hooked up
I SOHC!!!
I my EF!!!
I ♥ my EJ8!!!
1991 Honda Civic Hatchback Si
1998 Honda Civic Sedan EX
19si91 is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 03:59 PM   #5 (permalink)
BiggieBert's Avatar
Is that reading threw the mtx or your ems?
Old 08-16-2012, 04:00 PM   #6 (permalink)
white wire is grounded.
just recalibrated it and same thing pegs out at 22.4
threw the gauge i dont have any way to read ems
PM me for
Old 08-16-2012, 04:02 PM   #7 (permalink)
BiggieBert's Avatar
Maybe bad sensor? Does the car feel like its running that lean?
Old 08-16-2012, 04:04 PM   #8 (permalink)
well it is 6:1 so...... lol
PM me for
Old 08-16-2012, 04:14 PM   #9 (permalink)
Zer0DazE's Avatar
Rep Power: 10 Zer0DazE is hot as a volcanoZer0DazE is hot as a volcano
Zer0DazE is hot as a volcanoZer0DazE is hot as a volcanoZer0DazE is hot as a volcanoZer0DazE is hot as a volcanoZer0DazE is hot as a volcanoZer0DazE is hot as a volcanoZer0DazE is hot as a volcano
Put a multi-meter on the analog out
My car hates me.
Zer0DazE is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 04:15 PM   #10 (permalink)
those wires arnt hooked up
PM me for
Old 08-16-2012, 04:18 PM   #11 (permalink)
xotic_crx's Avatar
Rep Power: 20 xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!
xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!xotic_crx is the fucking MAN!!!!
Send a message via AIM to xotic_crx
Yeah, atmospheric is 5V IIRC, or close to it. See if that's what it's reading on the output.
2011 TLAC Series SMF Class Champion
2011-2014 Red River Region SMF Class Champion
< Like us on FB
xotic_crx is offline   Reply With Quote Quick reply to this message
Old 08-16-2012, 04:22 PM   #12 (permalink)
or should i check them anyway even though not being used
PM me for
Old 08-16-2012, 04:36 PM   #13 (permalink)
xotic_crx's Avatar
It will tell you how much voltage it's putting out.
< Like us on FB
Old 08-16-2012, 04:42 PM   #14 (permalink)
Zer0DazE's Avatar
Exactly
Put a multi-meter on the analog out. You will see if the gauge matches the output... it should with that unit being that the controller is the gauge.
My car hates me.
Old 08-16-2012, 05:33 PM   #15 (permalink)
there are 2 plugs 4 pin each one labeled out other in. then 2 loose wires one yellow one brown
i couldnt get a constant reading form the loose wires nor the 4 pin out plug.
it would just jump all over the place
PM me for
Old 08-16-2012, 05:46 PM   #16 (permalink)
Zer0DazE's Avatar
There should be 2 analog outs on that unit, and I believe they are both programmable like the LC-1. Your reading from both should around.
1 might be a 0-5v and the other 0-1v by default, but that is just a guess.
My car hates me.
Old 08-16-2012, 05:52 PM   #17 (permalink)
tell me what to probe
http://www.innovatemotorsports.com/s...Manual_1.1.pdf
PM me for
Old 08-16-2012, 06:04 PM   #18 (permalink)
Zer0DazE's Avatar
Dude, page 4
4. Optionally, the YELLOW (Analog out 1) and/or BROWN (Analog out 2) can be
connected to the analog inputs of other devices such as data loggers or ECUs. If
either one or both of these wires are not being used isolate and tape the wire(s) out
of the way. The default analog outputs are as follows: Analog output one (yellow) is
0V = 7.35 AFR and 5V = 22.39 AFR. Analog output two (brown) is 1.1V = 14 AFR
and .1V = 15 AFR. This is a simulated narrowband signal.
(I was right about the output)
read pages 9-11 to learn how to program them
You owe me a pint for the leg work
My car hates me.
Old 08-16-2012, 06:07 PM   #19 (permalink)
dude you owe me something cause i posted this already lol
PM me for
Old 08-16-2012, 06:23 PM   #20 (permalink)
Zer0DazE's Avatar
I read that, and I was right in my assumption that you had no idea what they were.
RTFM
You will NOT get a constant reading from them, you are not supposed to. You should get a reading (in voltage) that matches what is being displayed on your gauge. If not then there is an issue with the display/controller.
read pages 9-11 like I said to program your outputs, and put a multi-meter on one of outputs. It will give you a voltage that will move around, but the 0-5V shouldn't move more than 1v. You can convert that voltage to a AFR based on the way you programmed that output, and then you can see if it matches the display (give or take a little).
If everything is working properly then the analog outputs should match what is being displayed on the gauge.
2 pints
My car hates me.
iconAll times are GMT -8. The time now is 05:29 PM. | Welcome to Forum, please register to access all of our features.
