Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Management
Old 07-09-2009, 01:06 PM   #21 (permalink)
uxaxi's Avatar
Rep Power: 3 uxaxi smells like Boratuxaxi smells like Boratuxaxi smells like Boratuxaxi smells like Boratuxaxi smells like Borat
BUMP for the update
95 Dx Hatchback
4-2-1 Header
2.25 exhaust with a 24in. Resonator
magnaflow muffler
KYB AGX's
Skunk2 lowering springs. 2.5front 2.25rear
B&M short shifter
AEM Cold air intake
Thick half sized radiator from go-autoworks
Staying that way till next year.
Turbo b20vtec, here i come.
uxaxi is offline   Reply With Quote
Old 07-09-2009, 02:43 PM   #22 (permalink)
singleslamhp's Avatar
Rep Power: 4 singleslamhp is almost a somebodysingleslamhp is almost a somebodysingleslamhp is almost a somebodysingleslamhp is almost a somebody
Why do you take the ostrich out of the car to program it? No Laptop? Is it throwing a solid cell or a code?
1991 CRX HF, D16a6, Eagle rods, SRP pistons, Modded KMS Block guard, Endyne block posts, ARP Headstuds, OBX LSD, LSD 6-puck Clutch, motorolla 2.5 bar map, portmatched head and manifolds, Ebay cast mani, Ebay intercooler, Bullseye 57 trim turbo, HKS BOV, Tial Wastegate, turbonetics BC, Precision 680 injectors, Custom charge pipes, 2 1/2" VRS exhaust, dynomax muffler, walbro 255, HR springs, KYB AGX shocks, Innovative traction bar, Turbo edit.
singleslamhp is offline   Reply With Quote
Old 07-09-2009, 02:52 PM   #23 (permalink)
uxaxi's Avatar
i have a laptop but the battery lasts like. . 20 minutes maybe? The computer is always turned on. . Its probably been turned on for the past year. . restarts every few days maybe?
Crome didn't detect a CEL but my car says there was one, guessing it was solid
95 Dx Hatchback
4-2-1 Header
magnaflow muffler
KYB AGX's
B&M short shifter
AEM Cold air intake
Old 07-09-2009, 03:30 PM   #24 (permalink)
D-series.org Sponsor
Rep Power: 7 ghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebodyghettoturbo is almost a somebody
What do you mean Crome didnt detect a cel? You aren't datalogging are you?
When you are taking the ostrich out, are you leaving the ribbon cable in the ecu and unplugging it from the ostrich, or are you pulling the ribbon cable out of the ecu? My bet is that you have a shaky connection somewhere (like where the ribbon cable goes into the ZIF/DIP socket), and the slightest movement is causing all your issues.
"customer service" AIM: xenocronHELP
ghettoturbo is offline   Reply With Quote
Old 07-09-2009, 05:29 PM   #25 (permalink)
uxaxi's Avatar
ya it was datalogging and the CEL said it was off in crome.
I leave the ribbon attatched to the ecu. I have it so the ribbon is comming out of the closed ecu, i shaved a bit off the side of the ecu so the data logging cable and ribbon could come out of the ecu without getting cut.
95 Dx Hatchback
4-2-1 Header
magnaflow muffler
KYB AGX's
B&M short shifter
AEM Cold air intake
Old 07-10-2009, 12:14 PM   #26 (permalink)
uxaxi's Avatar
Lol, thats why your the professional and i'm not.
I'm guessing you're right, i took the ribbon outa the ecu and found a kink in it, like where 8 of the wires are bent and probably not making a connection, and it worked sometimes because maybe the ribbon was at the right spot to make it work. . I dunno
I put my old chip in and it works fine but the guy that gave it to me said it has more fuel/timing than the stock maps so i need to find someone around here that'll either burn me a new chip with a p28 map but a bit leaner.
Mr crab? Do you happen to have a chip burner in that garage of yours?
EDIT: I tried taking the ribbon to a computer store "not bestbuy or anything like that" but a random shop to see if he could fix the ribbon. . . He said no. I asked if he could take the ribbon outa the plastic 28 pin thing and move it back a bit. . . .He said no.
Bitch.
95 Dx Hatchback
4-2-1 Header
magnaflow muffler
KYB AGX's
B&M short shifter
AEM Cold air intake
Old 07-11-2009, 04:53 PM   #27 (permalink)
uxaxi's Avatar
Bump. Anyone around tacoma with a ribbon cable thingie? Or know if speedfactory has them in stock?
Xenocron has them for 10 bucks but i dont wanna wait for shipping =\
95 Dx Hatchback
4-2-1 Header
magnaflow muffler
KYB AGX's
B&M short shifter
AEM Cold air intake
Old 07-12-2009, 10:29 PM   #28 (permalink)
uxaxi's Avatar
BUMP for the update.
95 Dx Hatchback
4-2-1 Header
magnaflow muffler
KYB AGX's
B&M short shifter
AEM Cold air intake
Old 07-16-2009, 04:55 AM   #29 (permalink)
SOHCpower's Avatar
Rep Power: 5 SOHCpower  is accepted as part of the communitySOHCpower  is accepted as part of the communitySOHCpower  is accepted as part of the communitySOHCpower  is accepted as part of the community
i got my ribbon cable for free from moates. but it was cause it was DOA. i sent the unit back and they tested and sent me mine back with new cable.
you can get a floppy drive ribbon cable and cut it and crimp the ecu side onto it.
SOHCpower is offline   Reply With Quote
iconAll times are GMT -8. The time now is 08:27 PM. | Welcome to Forum, please register to access all of our features.
