Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Building
Old 01-24-2009, 01:06 AM   #61 (permalink)
lsbrasil's Avatar
Rep Power: 2 lsbrasil is nobody
Choose whatever you want to use and balance it in a machine shop (all the rotative set)... You'll have NO problems at all... Just remember to choose a machine shop that actually DOES balancing over 3,000 RPM. Mine (B16 and soon my D17 too) was 10,300.
My case, of course...
lsbrasil is offline   Reply With Quote
Old 01-24-2009, 01:13 AM   #62 (permalink)
I AM A MF!
Rep Power: 45 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
The moment of inertia of an object up at the front end of the engine is just such an exception. It's called a crankshaft tortional vibration damper, or crank damper for short. Back in the '80s, even top drag racers were substituting heavy crank dampers for lightweight aluminum "hubs" in the belief they would go faster. The reality is these hubs, although having a vastly lower moment of inertia, actually cut power, even under high-acceleration conditions. The reason they did so is that they did not suppress crank tortional flexure. Such vibrations were transmitted directly to the cam via the timing chain and, as a result, the valve event timing was adversely affected and valve bounce was aggravated. All this led to a reduction in power, and I'm not talking .5 to 1 hp here, but sometimes 12 to 14 hp on a 400-odd-hp engine. The bottom line here is, use a functional damper first and worry about its moment of inertia last. That way your motor will make more horsepower, longer.
I will always feed an inquisitive mind, prod a lazy noob and blast a disrespectfull bum.
transzex is offline   Reply With Quote
Old 03-08-2009, 09:46 PM   #63 (permalink)
mschoaff's Avatar
Rep Power: 0 mschoaff is nobody
if you balance a motor wile you build it it does not matter what you do not need a dampener. some engines are internally balanced and 90% of 4 cylinders are internally balanced. you can totally use light weight pulleys to reduce the rotational mass of the crank.
as long as it is balanced
mschoaff is offline   Reply With Quote
Old 03-08-2009, 09:50 PM   #64 (permalink)
cmgreen50's Avatar
Rep Power: 13 cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
^ if know enough to have your engines balanced you wont be stupid enough to ask about putting a chinese crank pulley on your dd. which is why this thread was created.
Originally Posted by Dmod View Post
i seriously have a donkey if you're serious..
Originally Posted by Cade Johnson View Post
The problem is, my need for speed exceeds the need to save the earth.
Originally Posted by wizard's blood View Post
WELL FINE! I'LL JUST GO EAT THE SHIT OUTTA MY OREO'S THEN!
cmgreen50 is offline   Reply With Quote
Old 03-08-2009, 10:21 PM   #65 (permalink)
K2e2vin's Avatar
Rep Power: 7 K2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagleK2e2vin is fly like an eagle
:facepalm:
-Kevin N. E.
1988 Honda Civic hatchback; D15B VTEC Dac Biet
1992 Honda Accord LX coupe
Have a look-see: http://www.zeitgeistmovie.com/
K2e2vin is online now   Reply With Quote
Old 03-08-2009, 10:22 PM   #66 (permalink)
cmgreen50's Avatar
oh snap i thought he was talking about rebuilt motors that were balanced and blue printed
Old 03-08-2009, 11:35 PM   #67 (permalink)
ddd4114's Avatar
Rep Power: 9 ddd4114 is a Top Aussie
ddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussieddd4114 is a Top Aussie
Please don't post until you've read the entire thread...
93 EH2: b7/z6 mini-me
Originally Posted by SOHCitTOem View Post
is it really that hard to understand why you can't run with 17's? what happened to physics class bro? rotational mass, inertia, ring any bells?
Originally Posted by 880cent View Post
thx for info bro ................ but every law is meant to b broken
ddd4114 is offline   Reply With Quote
Old 03-09-2009, 01:09 AM   #68 (permalink)
cervan's Avatar
Rep Power: 12 cervan is hot as a volcanocervan is hot as a volcano
cervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcanocervan is hot as a volcano
Originally Posted by K2e2vin View Post
:facepalm:
x999
Have a question about lightweight front pulley? read this shit before posting:Lightweight pulley thread.
Originally Posted by House
If you could reason with religious people, then there wouldnt be any religious people.
My build in my CRX:
Y8 block with a z6 head stock z6 rods on a redneck portjob oil pump.
cervan is offline   Reply With Quote
Old 04-01-2009, 10:21 AM   #69 (permalink)
Idahocrx's Avatar
Rep Power: 3 Idahocrx is learning the way of the DIdahocrx is learning the way of the D
Quick question. I have an a6 damper with a sizeable chip in the power steering pulley part, shich i'm not goin to use. Can I grind it off myself or should i take it to my machine shop and get it machined off?
Here's a link to my prerunner
http://s10.desertboard.com/board/ind...ic,1287.0.html
I'm not in Idaho anymore!!!
Idahocrx is offline   Reply With Quote
Old 04-01-2009, 11:07 AM   #70 (permalink)
cervan's Avatar
I would think your fine, go ahead and grind it off, just make sure to leave the rest of it alone.
My build in my CRX:
Old 05-05-2009, 09:55 PM   #71 (permalink)
95RedVXCivic's Avatar
Rep Power: 2 95RedVXCivic is nobody
if the light weight pulleys are so bad, then this would be worse because of imperfections in grinding it by hand. plus, i have a d15z1 (i know, they suck) and it does not have a harmonic balancer on it, it is just a pulley. i have never seen an inline four cylinder that was not internally balanced, and if it was a problem with the pulley, then you would have the same problem with a lightweight flywheel as well. balancing is best, but you will NOT harm your engine by just putting a light weight pulley on it.
Its not a motor, its an ENGINE!
Originally Posted by Dsturch1 View Post
Turning wrenches would be much more fun than dispatching the po po anyday! Lol
95RedVXCivic is offline   Reply With Quote
Old 05-05-2009, 10:28 PM   #72 (permalink)
K2e2vin's Avatar
I'm going to assume you did not read anything in this thread.
-Kevin N. E.
Old 05-06-2009, 12:11 AM   #73 (permalink)
ddd4114's Avatar
Haha. I wonder what tipped you off...
Old 05-06-2009, 01:12 AM   #74 (permalink)
cervan's Avatar
*long drawn out sigh*
My build in my CRX:
Old 05-06-2009, 01:41 AM   #75 (permalink)
I AM A MF!
I refuse to entertain this idiot.
Old 05-06-2009, 08:57 AM   #76 (permalink)
Rep Power: 2 sabes is trying to make new friends
LMFAO!!!!
sabes is offline   Reply With Quote
Old 05-06-2009, 03:35 PM   #77 (permalink)
Rep Power: 0 TravisCadello is  EVIL !!!!!!!!
I call BS on this do not use lighter pulleys. I ran a Aluminum pulley on my B16a from 99 till 2005 and put over 85K miles on it no problems. I sold it to a Friend And hes been driving the shit outa it since 05 and no problems. the motor still runs great. matter of a fact i met up with him today and he was driving it. I lighter pulleys takes stress off the crank and lets it rev up more freely. And SPeaking of lightweight pulleys. My old d16z6 block i welded the pulley off a bad Honda Alternator onto my crank because my cranks threads broke that hold the stock pulley. and it never messed up after a year of driving it. but the welds came off.
TravisCadello is offline   Reply With Quote
Old 05-06-2009, 03:44 PM   #78 (permalink)
cmgreen50's Avatar
Originally Posted by traviscadello View Post
i call bs on this do not use lighter pulleys. I ran a aluminum pulley on my b16a from 99 till 2005 and put over 85k miles on it no problems. I sold it to a friend and hes been driving the shit outa it since 05 and no problems. The motor still runs great. Matter of a fact i met up with him today and he was driving it. i lighter pulleys takes stress off the crank and lets it rev up more freely. And speaking of lightweight pulleys. My old d16z6 block i welded the pulley off a bad honda alternator onto my crank because my cranks threads broke that hold the stock pulley. And it never messed up after a year of driving it. But the welds came off.
wtf is wrong with you
Old 05-06-2009, 03:46 PM   #79 (permalink)
K2e2vin's Avatar
I guess this thread shows how bad our school system is.
Honda, and many other companies who spend millions of dollars on R&D, obviously do NOT know what they're doing
-Kevin N. E.
Old 05-06-2009, 04:29 PM   #80 (permalink)
ddd4114's Avatar
How was it driven? What else was done to it? What's the b16a's stroke?
Please read the whole thread. If you chose to run a pulley without a damper, it doesn't mean that your engine is 100% certain the fail. It just makes it more likely, and the three questions I asked will tell you a lot about how reliable it will be.
Oh yeah, and how do you know it didn't have problems, aside from the fact that it didn't blow up? Did you ever tear the engine down?
iconAll times are GMT -8. The time now is 08:25 PM. | Welcome to Forum, please register to access all of our features.
