Will a broken water pump make noise? - D-series.org
Old 05-21-2008, 03:28 PM   #1 (permalink)
thelobster's Avatar
Rep Power: 10 thelobster will become famous soon enoughthelobster will become famous soon enough
Default Will a broken water pump make noise?
My coolant system isnt preassurizing.
example after operating the car for 20 mins i pop the hood and my hoses are still soft. I am able to take my rad cap off without releasing any air/preassure. Both my upper and lower hoses are hot. My car isnt over heating and operating at a normal temp.
if my water pump is busted would it make any noises?
300hp 260 tq - greddy kit 15g
thelobster is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 03:34 PM   #2 (permalink)
QShifter's Avatar
Rep Power: 11 QShifter is trying to make new friends
Whats the milleage of your car/engine? did you do any recent work on your car? Is there enough water/coolant in your engine and rad? do you see any leaks under your car from coolant? and last does it look like you have antifreeze in your oil? Depending on your water pump if blades deterioate over time from antifreeze it will still spin but not much coolant will get pumped thru the system.
1993 and 1995 Civic Hatch, Both retired now
D15B7 to D16 Swap:
QShifter is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 03:41 PM   #3 (permalink)
thelobster's Avatar
motor was rebuilt 1k miles ago. there is enough coolant in the rad and overflow. no leaks under my car. and no coolant in my oil that i can see.
Old 05-21-2008, 03:46 PM   #4 (permalink)
HondaPACT's Avatar
Rep Power: 11 HondaPACT is learning the way of the DHondaPACT is learning the way of the D
Send a message via MSN to HondaPACT
did you bleed your cooling system? it seems like you just have a big ass air bubble in it
88 Civic D16Z6 project:saddam:
psi is not created equal
HondaPACT is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 04:13 PM   #5 (permalink)
thelobster's Avatar
yes i bled it for 30 mins when i swapped motor.
Old 05-21-2008, 05:13 PM   #6 (permalink)
My 91 Crx Hf
bznc's Avatar
Rep Power: 11 bznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eaglebznc is fly like an eagle
iTrader Score: 22 reviews
does your heat work? like inside heat? cause when the waterpump goes the heater core doesn't get its supply
- My Egg
- Gone as well
- Sold
bznc is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 05:33 PM   #7 (permalink)
OMG TOTALLY COOL TITLE!!!!
si-hatch86's Avatar
Rep Power: 28 si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !si-hatch86 is on a level you can only DREAM about! ! !
iTrader Score: 15 reviews
Send a message via AIM to si-hatch86 Send a message via MSN to si-hatch86 Send a message via Yahoo to si-hatch86
start the car and take off the rad cap, after it gets to normal temp look and see if you can see the water moving in the rad.
RIP Pat Primmer
RIP MILO
si-hatch86 is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 05:41 PM   #8 (permalink)
thelobster's Avatar
i got heat
and ill try the movement thing later.
Old 05-21-2008, 05:44 PM   #9 (permalink)
My 91 Crx Hf
bznc's Avatar
has it overheated yet?? see if theres some moisture building up at the bottom timing belt cover if your waterpumps leaking it'll be coming out around there..
if it hasn't overheated I'd leave it alone haha, are the radiator hoses and such new? jw
- My Egg
- Gone as well
- Sold
Old 05-21-2008, 05:58 PM   #10 (permalink)
green_hornet_96's Avatar
Rep Power: 15 green_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eaglegreen_hornet_96 is fly like an eagle
Water pump doesn't pressurize the system, it just keeps things moving enough to let the radiator do its job. The expansion of the coolant mix is what causes pressure.
My car doesn't generate any perceptible pressure, ie. it doesn't go PSSHHH when I pop the cap, but I do see a difference in coolant levels in the overflow.
There was a time when it had a small leak at the radiator on the lower hose, when the coolant expanded it would push out but that's all I would lose.
Never has my system been like that of say, a Trailblazer. Pop the overflow cap on that sucker fast enough when it's hot and you better have 2nd degree burn treatment on hand. It sprays EVERYWHERE.
green_hornet_96 is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 05:58 PM   #11 (permalink)
thelobster's Avatar
no it hasnt overheated at all.
hose is new so are the clamps
Old 05-21-2008, 05:59 PM   #12 (permalink)
thelobster's Avatar
alright good to know. i guess mine is fine since i have heat and both top and bottom hose are hot, and i havent over heated yet.
Old 05-21-2008, 06:03 PM   #13 (permalink)
Spriggan's Avatar
Rep Power: 0 Spriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to allSpriggan is a name known to all
Send a message via AIM to Spriggan
if it was busted it would sound like marbles in a coffee can.
best thing to do is take off the rad cap then start the car. let it run like that and watch the radiator, when you see the coolant flush into the system start adding more in slowly until its full, the you know you are done.
Spriggan is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 11:35 AM. | Welcome to Forum, please register to access all of our features.
