removing pistons from the bottom of the motor? - D-series.org
Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Building
Old 06-08-2004, 05:43 PM   #1 (permalink)
Rep Power: 0 quest4boost is nobody
Question removing pistons from the bottom of the motor?
ok, my friend has a d16a1 with some p29 pistons in it. unfortunatly, the motor is still in the car which makes working on it harder. and to make matters worse, 15 years of heat, grease, and rust has bonded the the head to the block, i pounded on it with a mallet and then tried to pry it out with a crow bar and got nowhere. so now im thinking that i can remove the oil pan and take the pistons out from the bottom. has anyone done this before? how should i do it? what should i beware of?
quest4boost is offline   Reply With Quote
Old 06-08-2004, 05:48 PM   #2 (permalink)
is a douche bag
dragman99's Avatar
Rep Power: 0 dragman99 is nobody
probably scarring the carnk or the cyl. walls.
dragman99 is offline   Reply With Quote
Old 06-08-2004, 05:57 PM   #3 (permalink)
d16a6 power's Avatar
Rep Power: 10 d16a6 power is learning the way of the Dd16a6 power is learning the way of the D
Take the motor out first. Then u can remove the pistons from the bottom. Why would you do this while its in the car anyway?
d16a6 power is offline   Reply With Quote
Old 06-08-2004, 06:03 PM   #4 (permalink)
damage to the motor is ok, i mean, we already dented it up real nice with the mallet and scarred it with the crowbar, haha.
my major concern is how to take the crank with the pistons attached safely so i dont hurt myself or damage the pistons.
Old 06-08-2004, 06:06 PM   #5 (permalink)
this is because we dont have the tools to take the motor out, so this isn;t an option.
Old 06-08-2004, 07:46 PM   #6 (permalink)
Rep Power: 434 ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !ryan89crx is on a level you can only DREAM about! ! !
what is wrong with the motor that makes you not care whether you fuck up the block or not?
My CRX 12.87@109mph
Delta Cam, best bang for your buck!
http://img.photobucket.com/albums/v2.../made_Ryan.png
ryan89crx is offline   Reply With Quote
Old 06-08-2004, 08:15 PM   #7 (permalink)
calboi510
what are you guys doing, pounding it with a mallet...with all that effort, you could have probably sold the old parts and bought new OEM style pistons
i never once pounded my motor to take anything out. take off the oil pan, take off the head, then pop the pistons through the top, it's still a lot of work though
Old 06-08-2004, 08:50 PM   #8 (permalink)
Rep Power: 10 HumanResource is trying to make new friends
Wink
WORD
not trying to flame you, but if you don't have tools to REMOVE, I don't even wanna ask how you plan on installing them
any chance you're doing this barefoot?
HumanResource is offline   Reply With Quote
Old 06-08-2004, 09:59 PM   #9 (permalink)
And what are your plans with these pistons? They are used and will not work correctly in something else, thats whay you get a certain bore and the correct sized pistons to go with it. And your ruining a good motor by banging a crow bar on it, hmm thats nice. I hope your joking.
Old 06-08-2004, 10:05 PM   #10 (permalink)
CRX KING
slebidia's Avatar
Rep Power: 12 slebidia It's a JDM Star Bitches....
slebidia It's a JDM Star Bitches....slebidia It's a JDM Star Bitches....slebidia It's a JDM Star Bitches....
You cannot remove pistons from the bottom on a D-series block. Look down a bore of and empty block sometime and you'll see why.
DUAL POINT FOR LIFE!!!
slebidia is online now   Reply With Quote
Old 06-08-2004, 10:08 PM   #11 (permalink)
CRX KING
slebidia's Avatar
here:
Old 06-09-2004, 03:16 AM   #12 (permalink)
Rep Power: 0 7thGear is nobody
for one thing, even if you get them out through the back, how are u gonna put new ones in?you'll be the first that i know to put the pistosn in through the back,
altho to tell you the truth i see no problem with that
i have a slow car, but i drive it fast, but i wouldnt mind driving a fast car fast.
7thGear is offline   Reply With Quote
Old 06-09-2004, 06:36 AM   #13 (permalink)
ok, my friend bought this car to do a b16 swap or something in it, he does not plan to reuse the original motor in any shape or form and he does not want to bother with selling bits and pieces of the motor. this is why we decided to use such extreme force on it.
to all the people who are asking how the pistons are gonna go back in: i never said the pistons are to be reinstalled in the same motor they came out of. the plan is to use them in my y8 whose head is not fused with the block.
d16a6 power: why wont pistons from one motor work in another? dont people do this all the time? ITR pistons or CTR pistons in other b series blocks, turbo supra pistons in b series blocks, what is different about this case?
Old 06-09-2004, 06:41 AM   #14 (permalink)
Originally Posted by slebidia
here:
thank you for taking the time to answer my question.
Old 06-09-2004, 09:12 AM   #15 (permalink)
What are you talking about? I did with mine and how else would you do it? And the question about using other pistons is that they are new and there is a new bore for them to work correctly.
Old 06-09-2004, 09:14 AM   #16 (permalink)
CRX KING
slebidia's Avatar
If you're telling me you did you are a liar. Look at the bottom of the cylinder in the pic.
Old 06-09-2004, 03:21 PM   #17 (permalink)
I know you cant pull them out from the bottom, i thought you were saying you couldnt work on them from the bottom. i got mine out through the top, by pushing them from the bottom.
Old 06-09-2004, 03:31 PM   #18 (permalink)
Are the notches on the cylinder walls or is it the crank. I dont remember these on mine but i didn remove it through the bottom. If those notches are the crank then couldnt you remove the crank and take the pistons out with it through the bottom?Not saying i would do it but just a thought.
Old 06-09-2004, 03:43 PM   #19 (permalink)
DseriesScience
As far as I know, you are looking at the lower girdle of the block and removing the crank will not remove this blockage. that being said, the D is quite light and if you put 3-4 2X8's underneath you should be able to use three people to painlessly pull it out. clearly you have to take the hood off but even a comealong hooked on a rafter would be enough although renting an engine hoist is not all that expensive. Quit fighting it and pull it you'll be glad you did.
Old 06-09-2004, 04:22 PM   #20 (permalink)
take this block to the tallest building in your area and drop it to the ground
just an idea...
iconAll times are GMT -8. The time now is 01:55 PM. | Welcome to Forum, please register to access all of our features.
