What would cause a connecting rod bolt to break or loosen and allow rod knock or a ho - D-series.org
Old 07-21-2007, 03:56 AM   #1 (permalink)
BLACK-KNIGHT's Avatar
Rep Power: 11 BLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropesBLACK-KNIGHT is starting to learn the ropes
iTrader Score: 30 reviews
Default What would cause a connecting rod bolt to break or loosen and allow rod knock or a ho
What would cause a connecting rod bolt to break or loosen and allow rod knock or a hole in the block?
1-Crappy connecting rod bolts?
2-Oil pump causing over heating and bearing failure?
3-no oil in motor?
4-lack of the oil getting to bearing?
5-over torquing them to 25 lbs instead of 15 lbs?
6-It being a honda b or d motor stock with less than 2k on motor?
7-Making mad tight jdm power that lifts the rear wheels on a front wheel drive car?
8-clutch alignment belt?
This motor was bone stock b18 b1 with no mods and under 2k miles on new rebuild that was done correctly over 6 months time to make it painstakingly right.
I dont understand as why a stock motor throws a rod threw the side of a stock motor 140 hp beast? why?
BLACK-KNIGHT is offline   Reply With Quote Quick reply to this message
Old 07-21-2007, 04:08 AM   #2 (permalink)
Rep Power: 0 liveforphysics is learning the way of the Dliveforphysics is learning the way of the D
Using ones gears to slow down, often called engine braking will cause this type of failure. Engine braking puts peak stress on the lowerend, much more than WOT operation.
Over torque will cause bolt failures, as will under torque.
Loss of oil pressure will cause bearing failure in a fraction of a second. Bearing failure if not attended to quickly results in pounding the rod cap off and sending the rod through the block.
If you look at the parts it can become quite obvious as to what caused the failure.
Keep in mind, reguardless of the engine or its build, a single incorrect downshift can cause this problem.
I've got a pile of blocks with 'windows' installed in the sides of them...
liveforphysics is offline   Reply With Quote Quick reply to this message
Old 07-21-2007, 04:12 AM   #3 (permalink)
how much over torquing?
try to get pics today as i am taking part the motor today
Old 07-21-2007, 04:14 AM   #4 (permalink)
Bangin rev limit in down shift (not happened) what i mean is how can a down shift be considered incorrect?
Old 07-21-2007, 09:10 AM   #5 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
lack of oil to the bearing, it get hot, tolerances get tighter, it gets hotter then BOOM!
Old 07-21-2007, 09:35 AM   #6 (permalink)
Location: Puyallup, Washington.. But So Cal born&Raised and in my Heart
Rep Power: 0 SOHCinWA is about to kiss the sky
SOHCinWA is about to kiss the skySOHCinWA is about to kiss the skySOHCinWA is about to kiss the skySOHCinWA is about to kiss the skySOHCinWA is about to kiss the skySOHCinWA is about to kiss the sky
I have always been told that engine braking is bad... Down shifting at redline aint cool... Thats why they make $20.00 brake pads....
SOHCinWA is offline   Reply With Quote Quick reply to this message
Old 07-22-2007, 02:03 AM   #7 (permalink)
Slowing with gears makes massive amounts of engine bearing heat. The oil wedge is punished in both cycles when ever your throttle is closed and the engine is at high RPMs. Normally, the compression stroke helps to cushion the peak bearing stress point, which is of course stopping and re-starting the piston at TDC. Combustion force is hardly compairable. This is why rod bolts are so crucial in engines that spin.
iconAll times are GMT -8. The time now is 08:01 PM. | Welcome to Forum, please register to access all of our features.
