LinkBack (1) | Thread Tools | Display Modes |
#81 (permalink) | |
TURBO MAZDA-ING
модератор / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4, 350.4lbs |
#84 (permalink) |
New HG and head milling seem like easy things to do, but it will not increase cr anything significant, perhaps you'll go from from 9.2 to 9.7, at most. Though I have never used anything less than OE Honda HG and non-milled head, you should check other forums as well since they carry a ton of informtion on those topics (i.e. using less than OE HG and how much to mill). I have read a lot about less anything less than a OE Honda gasket might be dangerous and NOT recommended. Go with a basic mill job, no more than recommended , I think no more than .010 in, again I don't speak from experience, only what I read on these forums.
Like builthatch put in his initial post, using new pistons is the best way to go. Yes, you'll have to remove the motor/tranny, get a cherry picker and motor stand, but you'll also have to install all new seals, bearings, pumps, etc. The N/A power though will be much better. Last edited by martyr1391; 01-03-2006 at 08:38 AM. |
#86 (permalink) | |
TURBO MAZDA-ING
#88 (permalink) | |
TURBO MAZDA-ING
are you planning on tuning sometime? i speak from experience, not tuning is 10X the trouble and cost of just giving in and tuning. not to mention, tuning can be the difference between a waste of money and a great performer. the difference between a frown and a smile, if you will.
#90 (permalink) | |
TURBO MAZDA-ING
#92 (permalink) |
what pistons/compression would you suggest if im wanting to run a 50-75 shot of nitrous, i want to be able to run a fun motor on the street and when its time to go to the track, do a little spray. i am most likely going to go with an aftermarket piston just for a little piece of mind when spraying the juice, just not exactly sure what compression would be best and yet safest for my build.dont want to be to sluggish but yet dont want to run too high of compression and possibly run into detonation problems.
#93 (permalink) | |
TURBO MAZDA-ING
So, really, i'd go with the highest compression you can run comfortably (fuel availability, tune capability) and then spray ontop of that. There are a few ways to switch between a juiced and high cr tune; i used to use an MSD retard box; it would kick the timing back 4-6 degrees depending on the shot. Nowadays there are engine managements you can have actual juice tunes to run when the juice goes on and a solely high cr tune to go when you are all motor. This will allow you to have a tune which will allow you to run on pump gas and spray with the high CR. THe best bet would be a high CR tune, a high CR w/ spray on pump gas tune, and then a high CR w/ spray on race fuel tune. You would have to look at your tuning EMS options for that though.
#94 (permalink) |
Hi, I'm Max and I write from Italy, my car is a '97 EJ8 with a D16Y8.
It has 92k kmeters an it's practically completely stock. Here in Italy we've 95 or 98/99 octane fuel. I've rear your fantastic Topic (with big "T") and now I would like to do the same as you suggested: a powerful N/A D16. my friends with the knowledge that we have on d-series stops to sotf tuning with engine power of about 140 HP and the major of them swaps on B-series. I like my d16 and i don't want to swap. My question is: if I would like to buy some used components from you guys on this forum, is there anyone that could help me? for example, do I have to buy P29 pistons? or can I mantain my originals? for my specific engine what is the best and cheap setup? naturally I'll reach the power that I pay eheheh wich components I can recover from old models? thank u very much byezzzzzzzzzzzzzz Xam Last edited by xamtomcat; 01-31-2006 at 04:11 AM. |
#95 (permalink) |
I know that you guys are getting sick of these questions from noob's like me but I am absolutely at a loss here. I wyould like to run the p29's but with any of the cr calculators I am comming up with a minimum of 11.6:1. I would like to stay around 11.0:1. I am running a complete y8 block/head so I was woundering if I simply ran the a6 pistond with about 0.020 milling on the head if this would bring me anywhere near 11.0:1. The cr calc's dont allow for head milling. I simply subtracted .020 from the head gaskets thickness and it gave me a 10.8:1 cr. If this is accurate then I would be happy with this. Now what if I overbored by 0.020? I would immagine that this would only add to the compression. Also I was woulndering what cam I should run with this, would the stage 3 still be a good choice? Will the stage three cause any idling issues?
Thanks guys Ken |
#96 (permalink) | |
TURBO MAZDA-ING
in my thread, i mention that you can select a head gasket to get to the compression ratio you need, so if you do the math for the Greddy headgasket in a y8, you get 11.2:1. Greddy headgasket, 2mm=.0787". You are right, the compression w/ the a6 pistons, y8 gasket and .020 from the head would be about 10.8. If you were to overbore by half a millimeter, 75.5 a6 pistons, and milled that .020, you would be at practically 11:1. if you want to calculate overbore, just add to the bore at the top of the calculator. Also, a rough estimate feature for milling the head is indeed subtracting from the headgasket thickness. the Crower 3 cam is wild, and needs alot of tuning to have a decent idle...but it's doable. Remember it needs some moderate to major head porting to work well! Crower 2 is a nice upgrade that doesn't necessarily need all the porting (on y8 i'd still port no matter what) and it idles "ok".
модератор / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4, 350.4lbs Last edited by builthatch; 01-31-2006 at 05:11 AM. |
#97 (permalink) |
for tuning what do I plan on running a P28 chipped. I have a guy who will chip it and dyno tune it for 100$. I think its a very cheap price. Will i have to tow my ride to the shop for tuning or will a base map be sufficient enough to get me up and running? If I can run a base map where can I get it?
#98 (permalink) | |
TURBO MAZDA-ING
#99 (permalink) | |
TURBO MAZDA-ING
the p29 piston is essential for the high compression you need to make power. pretty much everything else can be used that is already on or in your motor, however, you DEFINATELY need to swap the pistons (obviously) and tune. Additional parts and mods from there, if the right ones are chosen, will increase power. Ported head, big cam, nice intake manifold, nice header, etc.
#100 (permalink) |
Thanks!!!
and... for italian women, you're right!!! i love them too byezzzzzzzzz PS: - but of wich engine are that pistons(P29)? - can y8 block,rods and the other parts resist to that compression? - how much i can pay for used P29s ? ***edit*** - if I only swap the P29s on my engine wich c/r will I reach and about how many HPs?(I think anyway that they could'n go on stock motor ehehe) - with 95 or 98 fuel could I have detonation risks? thankyou very much Last edited by xamtomcat; 02-01-2006 at 04:39 AM. |
LinkBacks (?)
LinkBack to this Thread: http://www.d-series.org/forums/engine-building/21761-building-powerful-street-na-d16y8-z6.html
| Posted By | For | Type | Date | |
| IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - d16y8 build | This thread | Refback | 04-24-2009 04:24 PM | |
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
