LinkBack (1) | Thread Tools | Display Modes |
#41 (permalink) |
dang
i just spent 580$ on my arias 11 compression pistons i do have the crower stage 3 cam along with the valves and springs skunk2 ti retainers and skunk2 adj cam gear waiting on my eagle heavy duty h-beam rods and then im headed to the machine shop milling the head .030 to get the compression a little over 12 pnp, 3 angle valve job etc will be done as well |
#42 (permalink) |
now I have my d16a6 block. I figgured out that this block with p29 pistons, y8 head and a6 headgasket rise the compression to 12,3. Is the a6 gasket ok? because its much cheaper then an cometic or apexi gasket
current setup: ported d16y8 head AEM TRUTIME camgear 105300 cam ferrea 20º Super Flo. 1 mm oversize valves zex valve springs Edelbrock Performer X 62mm TB d16a6 block 76mm p29 pistons walbro 255lph 100cel catalytic convertor fidanza 7lbs flywheel dc2 catback comptech header CROME tuned p28 ecu 12,5:1 cr 4,43FD http://img143.imageshack.us/img143/6483/civicoi8.jpg |
#43 (permalink) | |
TURBO MAZDA-ING
12.3:1, with a good tune (wide-band, heathy a/f and conservative timing maps), cold spark plugs and 93 or 94 octane is definately doable. what thickness and material is that gasket? is it OE honda?
модератор / '08 Mazdaspeed3 GT / '07 Si sedan / END OF AN ERA / 6'4, 350.4lbs |
#44 (permalink) | |
TURBO MAZDA-ING
#45 (permalink) |
you damn right!! it has spray me written all over.....neptunes is kinda expencive thou....
$20 dollar Jose bitches.... what would u do 4 a 20 twin twin... http://www.superhonda.com/photopost/...773pimpgif.gif |
#46 (permalink) | |
TURBO MAZDA-ING
#47 (permalink) |
yeah bad i was thinking about the whe you want to distribute it...its 5gs to become a dealer as apose to 150 bux for crome....
#48 (permalink) | |
i dont know, I think the oem gasket is metal. Which spark plugs did you mean, the oem honda? yes the ecu get a good tune, and we have 98 octane in germany
#50 (permalink) | |
TURBO MAZDA-ING
#51 (permalink) |
i have a
D16A6 Block. D16Z6 Head. Crower Stage 2 cam, springs, retainers. Omni power valves. A-N-R Header. Edelbrock Intake Mani. Edelbrock 65mm Throttle Bodie. ZC Pistons. Eagle H-Beam Rods. All ARP Bolts. 255 Walbro. 310 injectors. 3 angle valve jobs. port~n~Polish. and want to run an S20 Tranny if i can ever find one. I hope to make around 170 WHP. Tuned with Crome. P28 ECU. OBD-1 is this reachable with my setup. |
#52 (permalink) |
Cool User Title Here
Location: 7.5 hours north of Modshxcivic, 6.5 hours north of Rexinre's house (he says only 5 hours) (MAINE)
You should be able to do it with race gas.....pump gas....iffy, unless you run some major timing, and have thatthing tuned perfectly
My Old Car |
#54 (permalink) |
this is an awesome thread with lots of info. i just wanted to give props to builthatch for compiling all of this information for us. i've been thinking more and more about an NA build lately, and how much easier could it get then using a bunch of OEM parts, lol.
http://i57.photobucket.com/albums/g2.../japan_sig.jpg |
#55 (permalink) | |
Location: land of happy motoring, sunny northern california
AKMEE D16Z6/Y8 Type-S cam dyno tuned - 138.8 whp; 7.8 whp peak, 20.4 whp @ 7700! G.SPEED Racing Est. 1995 - http://www.g-speed.com AKMEE Engineering Est. 2004 - http://www.akmee.com ex b16a.com owner (b16a fan since 1989) 95 EG2 del Sol VTEC - big red delly-O 94 EG6 Civic Si - project remix representing SOHC! RIP remix! I will miss you so much. project remix2 - EF wagon?! Z6 turbo? |
#56 (permalink) |
nice post builthatch, what do p29 pistons weight?
#57 (permalink) | |
TURBO MAZDA-ING
i used to have the weights of all the d pistons (for some reason) if i recall, they are almost the same weight as a6 pistons.
#58 (permalink) |
larry's NA roller waves are listed at 280 grams, pins 80 grams. what do stock z6 pistons weight? i'm pleasantly suprised by the performance of my z6, now i want to do a budget NA build...
#60 (permalink) | |
TURBO MAZDA-ING
i also am thinking that there would be a rod journal size mismatch to the d16 crank if you used anything else... it's been a while since i've had to think about this, but i think i am right....correct me please if i am wrong. another thing to consider, even if you could get an appropriate rod situation to keep it the right height in the cylinder is the relationship w/ a big cam opening the valves vs. the reliefs on the pm3. if you favor a flat top piston, you could look into a pg6b piston from 86-87 teg, however, with a big cam, there is concern about the valve reliefs in my mind. i know people who have had the reliefs machined for clearance, but i have no personal experience with using these pistons.
LinkBacks (?)
LinkBack to this Thread: http://www.d-series.org/forums/engine-building/21761-building-powerful-street-na-d16y8-z6.html
| Posted By | For | Type | Date | |
| IMPORTATLANTA.COM - Automotive, Lifestyle, Offtopic, Forum, Blog, & Online Community - d16y8 build | This thread | Refback | 04-24-2009 04:24 PM | |
