help!! zc crank in y8 block - D-series.org
Old 10-27-2013, 12:16 PM   #1 (permalink)
Rep Power: 0 8000rpms is nobody
Question help!! zc crank in y8 block
i have a zc crankshaft in a y8 block...ive built the motor already i just cant time the damn thing i have a skunk 2 cam gear if that helps
i know they are interchangeable
and it would be good to get the y8 oil pump ported and "shimed"
but what about the timing!!
8000rpms is offline   Reply With Quote Quick reply to this message
Old 10-27-2013, 12:47 PM   #2 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 15 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
If its a y8 cam use the y8 cank pulley set timing the way it says for a y8 in the fsm. If its a z6 cam use the z6 crank pulley or the zc one and time how the fsm says
d17y8 custom ITB's, NA HP build
homemade small IC engine
homemade alu rods pistons
Old 10-27-2013, 01:01 PM   #3 (permalink)
everything im using is y8...still timing is off
Old 10-27-2013, 01:25 PM   #4 (permalink)
Evanguy's Avatar
your timing it wrong, set the bottom end to top dead center, then set your cam so the marks sit level with were thw valve cover seals and slide the timing belt on, also put you cam gear at 0* if its a Y8 gear set it to 4.75* advanced if its a Z6 gear. make sure by the part number because there are alot that say for 88-00, i know my skunk 2 gear needs to be 4.75* advanced to work on a y8 cam.
also plort the oil pump sure, dont shim it though. more pressure != more volume
Old 10-27-2013, 04:47 PM   #5 (permalink)
Thx I will try that
Have you done this build
Old 10-27-2013, 05:25 PM   #6 (permalink)
Evanguy's Avatar
well i used a d17 crank in my d16y8 bottom end as well as a y8 head and cam. so the same thing as you but a d17 crank, as far as timing goes d16 cranks and d17 cranks are the same. its the cam that makes the difference or the block height(d15) when mechanically timing a dseries
iconAll times are GMT -8. The time now is 04:07 PM. | Welcome to Forum, please register to access all of our features.
