JDM D15 Non VTEC to D16Y8 mini-me head swap - D-series.org
Old 10-09-2013, 01:10 PM   #1 (permalink)
UncleLuke's Avatar
Rep Power: 0 UncleLuke is nobody
Default JDM D15 Non VTEC to D16Y8 mini-me head swap
Had a few parts list questions before I get under way.
Can I use my valve cover from the JDM D15 Non VTEC?
Can I use my distributor from the JDM D15 Non VTEC?
Can I use my timing belt from the JDM D15 Non VTEC?
Can I use my head gasket/studs from the JDM D15 Non VTEC?
It is a low mile JDM D15 Non VTEC I got from an importer a couple years ago, it has been a great motor so far. My tuner set me up on ectune and will be engaging VTEC via ecu. I did the intake manifold swap with the manual transmission. And it has a cheap 4-2-1 header and intake. Otherwise everything else is stock on the motor.
99 Civic DX-VP sedan
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
UncleLuke is offline   Reply With Quote Quick reply to this message
Old 10-09-2013, 01:23 PM   #2 (permalink)
\/Your Mom Was Here\/
BeerDrinkin's Avatar
Rep Power: 48 BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !BeerDrinkin is on a level you can only DREAM about! ! !
Vtec valve covers are usually different than non-tec. The spark plugs on vtec models go in the front as the non-tec in the rear. I am only working on what I remember seeing of the d15b non-vtec models.
2005 Civic EX Sedan (ES2)
Old 10-09-2013, 01:51 PM   #3 (permalink)
UncleLuke's Avatar
That above pic is my late model JDM D15 Non VTEC. It has the spark plugs in the front, much like my D16Y7 Non VTEC did.
I think with the later models, OBDII, they were different, relocated dipstick too.
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
Old 10-09-2013, 02:28 PM   #4 (permalink)
You must have an odb2 motor, I thought that was the y8 you were posting lol. I seen the dipstick on the side and assumed it was the y8.
If I was you I would order a y8 or z6 MLS type headgasket when installing, they are much better than the composite gaskets the others use.
Other than that I don't know as much about the mini part of it. GL
Old 10-09-2013, 02:30 PM   #5 (permalink)
UncleLuke's Avatar
Looks like I am going to get an OEM D16Y8 head gasket too.
thx repped.
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
Old 10-09-2013, 03:53 PM   #6 (permalink)
97-Civic-Ex's Avatar
Rep Power: 9 97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all97-Civic-Ex is a name known to all
iTrader Score: 23 reviews
YES
I think so
You have to use the d15 timing belt, cannot use any D16 timing belt they are too long
Beerdrinker answered the HG already, as for studs,... not sure
97-Civic-Ex is offline   Reply With Quote Quick reply to this message
Old 10-09-2013, 04:59 PM   #7 (permalink)
Rep Power: 0 bairdandrew77 is nobody
97-civic-ex: I'm sure he has to use a y8 VTEC dizzy. The non-vtec dizzy wouldn't work without modifications
My 89 CRX DX mini me build thread:
bairdandrew77 is offline   Reply With Quote Quick reply to this message
Old 10-09-2013, 05:13 PM   #8 (permalink)
What modes are you talking about? Remember, he has the obd2 non-vtec d15b which is equivilant to a d16y7. Y7 and y8 share dizzies.
Old 10-09-2013, 07:23 PM   #9 (permalink)
Never mind, A quick search showed I was wrong :saddam: Apparently the distributors are the same between them if it really is equivalent to the y7. My bad
Old 10-10-2013, 08:22 AM   #10 (permalink)
UncleLuke's Avatar
Correct, my OBDII JDM D15 Non VTEC uses the equivalent to a D16Y7 distributor
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
Old 10-10-2013, 11:48 AM   #11 (permalink)
also a quick reminder that when putting a d16 head (like the y8 you intend to use) on a D15 block, use the d15 cam gear.
Old 10-10-2013, 02:31 PM   #12 (permalink)
UncleLuke's Avatar
My JDM D15 motor is a D16Y7 equivalent block, not the D15B7 block you are referring to with the D15 cam gear and D15 timing belt posts above.
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
Old 10-10-2013, 02:45 PM   #13 (permalink)
Rep Power: 23 xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!xile6 is the fucking MAN!!!!
As said.
It's a USDM y7 so treat it like a y7 which means the y8 parts will fit.
Valve covers are all the same for d obd2 motors.
Old 10-10-2013, 03:22 PM   #14 (permalink)
your jdm d15 block is still 1/4" smaller than the D16y8 block you are taking the head from. You must compensate for that or you will be 4.5 degrees off. Unless you are using a d15b vtec head and not a d16y8 head, you will have to swap cam gears. You should try and really understand it some more, so here is a quick link:
D15b 3 stage engine control
Old 10-10-2013, 03:50 PM   #15 (permalink)
UncleLuke's Avatar
I thought that the JDM D15 non VTEC block = US D16Y7 block?
and US D16Y7 block = US D16Y8 block?
JDM D15B
Y8 transmission
P06 OBD1 ectune
Phearable tuned
Old 10-10-2013, 04:16 PM   #16 (permalink)
No, the d15 and d16 designate the displacement,... i.e. 1.5 liter and 1.6 liter displacement. Since pistons are both 75mm, the added displacement comes from the block height/rod stroke. So when we say an obd2 nonvtec jdm d15b motor is equivalent to an obd2 d16y7 motor, we mean for all intents and purposes, they use the same things,… except the blocks are d15 vs d16 so there are a few things that have to be different.
So you if you don’t understand the differences, I’d suggest you read a little more to make sure you do. Nothing will blow up if you get the cam gears mixed up, it will just feel like it is out of timing and you will not know why. As you can tell from the link, I have had both a JDM d15 head and a usda d16 head that are equivalent and have seen the differences,…. i.e. the cam being one of them.
From what I have researched and seen firsthand, an obd2 jdm d15b block (vtec or otherwise) mated to a USDM d16 head (vtec or otherwise) will require a d15 cam gear.
Old 10-10-2013, 04:31 PM   #17 (permalink)
No, the d15 and d16 designate the displacement,... i.e. 1.5 liter and 1.6 liter displacement. Since pistons are both 75mm, the added displacement comes from the block size and stroke. So when we say an obd2 nonvtec jdm d15b motor is equivalent to an obd2 d16y7 motor, we mean for all intents and purposes, they use the same things, except the blocks are d15 vs d16 so there are a few things that have to be different.
So you if you dont understand the differences, Id suggest you read a little more to make sure you do. Nothing will blow up if you get the cam gears mixed up, it will just feel like it is out of timing and you will not know why. As you can tell from the link, I have had both a JDM d15 head and a usda d16 head that are equivalent and have seen the differences,. i.e. the cam being one of them.
I think you might be wrong on some of that.
From what I have read is the head and cam gear are the same as the usdm obd2 motors.
And the blocks where different as crank and rods. Same oil pump tho.
But either way a y8 head should swap over easily and keep the d15b belt.
Old 10-10-2013, 04:37 PM   #18 (permalink)
I will not repeat it,... read the link. Measure the block. Measure cam gear keying. Do your own research. Come back with facts. I am just trying to help him out with what I have read, researched, and done myself.
FYI, NO THE CAM GEARS ARE KEYED DIFFERENT TO COMPENSATE FOR THE DECK HEIGHT DIFFERENCES. READ THE LINK or should I repost my own research here?
and yes the head will swap in and yes the timing belt has to be the d15 as I stated before
Old 10-10-2013, 07:34 PM   #19 (permalink)
D Series Cam Gear Info - OBD2
Y8 and d16a r the same.
Z6 and d15b are the same. My bad.
Old 10-10-2013, 08:35 PM   #20 (permalink)
Rep Power: 0 Isidrogaricia405 is nobody
I have one question how many pounds can you put on a D15B without blowing the engine?
Isidrogaricia405 is offline   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 11:35 AM. | Welcome to Forum, please register to access all of our features.
