Plastic gage and bearing HELP !! - D-series.org
Old 02-23-2012, 02:29 PM   #1 (permalink)
Rep Power: 6 HPfreak is nobody
Default Plastic gage and bearing HELP !!
Hi guys i just messurd my STD Acl main bearing with a plastic gage but out of a 6 theres one that is slitly off and its the one in the midle can that do somthing is slitly off its a d16zc block if that can help
Thanks guys !!
HPfreak is offline   Reply With Quote Quick reply to this message
Old 02-23-2012, 02:32 PM   #2 (permalink)
crxlifer21's Avatar
Rep Power: 12 crxlifer21 is a Top Aussie
crxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussiecrxlifer21 is a Top Aussie
iTrader Score: 24 reviews
Originally Posted by HPfreak View Post
Hi guys i just messurd my STD Acl main bearing with a plastic gage but out of a 4 theres one that is slitly off and its the one in the midle can that do somthing is slitly off its a d16zc block if that can help
Thanks guys !!
Slightly off by how much? What did they measure out to?
JB weld has finally been used on this build!
from here on out all will be healed due to the honda holy water (jb weld)
302hp/262TQ
crxlifer21 is offline   Reply With Quote Quick reply to this message
Old 02-23-2012, 03:00 PM   #3 (permalink)
Its a bit smaller
Old 02-23-2012, 03:37 PM   #4 (permalink)
99ctrhatch's Avatar
Rep Power: 12 99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all99ctrhatch is a name known to all
Plastigauge just gives you a basic idea if it is within spec. You probably will have to use the correct measuring devices to find the exact clearance.
99ctrhatch is offline   Reply With Quote Quick reply to this message
Old 02-23-2012, 04:14 PM   #5 (permalink)
5 of them are .038mm
And the other one is .051mm
Old 02-23-2012, 04:17 PM   #6 (permalink)
snm95ls's Avatar
Rep Power: 23 snm95ls Still a JDM Star....
snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....snm95ls Still a JDM Star....
iTrader Score: 16 reviews
3 of them are .038
Using units sure does help convey you point.
I am going to ASSume you are giving us the measurements in mm.
Are we talking about rod journal or main journal clearances here? I have to again ASSume that we are talking about rod journals as you only listed 4?
06 Legacy GT Spec B DD
2017 Suzuki SV650
snm95ls is offline   Reply With Quote Quick reply to this message
Old 02-23-2012, 04:38 PM   #7 (permalink)
Sorry
Yes its in MM
And its crank bearing clearance ,i ment 5 not 4 lol
Old 02-24-2012, 12:51 AM   #8 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 15 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Sorry
Yes its in MM
And its crank bearing clearance ,i ment 6 not 4 lol
5 main journals and 4 rod journals??. its a 4 cylinder guy. where would the 6 journal be? you have you 2 ends and your 3 between the rods.
unless you have a
19921994 2.5 L G25 (Vigor)
19951998 2.5 L G25 (TL)
then you would have 6 main journals seeing how they are inline 5 cylinders, and i would be wrong
d17y8 custom ITB's, NA HP build
homemade small IC engine
homemade alu rods pistons
Old 02-24-2012, 03:48 AM   #9 (permalink)
unless you have a
4 are good and 1 is slitly off
Sorry my bad
iconAll times are GMT -8. The time now is 04:06 PM. | Welcome to Forum, please register to access all of our features.
