d15b2/d16z6 mini me - D-series.org
Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Building
Old 06-25-2011, 12:18 AM   #1 (permalink)
89c1vicdx's Avatar
Rep Power: 3 89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle89c1vicdx is fly like an eagle
Default d15b2/d16z6 mini me
hey new here im lookin to do a mini me on my 89 civic dx an need to know what all parts i need an exactly how to do it iv looked all over web an there is so many ways of doin it im lookin for the easiest an correct way to do it
89c1vicdx is online now   Reply With Quote
Old 06-25-2011, 12:27 AM   #2 (permalink)
Zen Chameleon's Avatar
Rep Power: 4 Zen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to allZen Chameleon is a name known to all
isn't that basically what 88CRX has been working on? if so then he will be right in to help lol
EDIT: or not haha
Delilah '97 Del Sol S
Originally Posted by transzex View Post
grab your rod and shake it, it the piston rattles you are OK!
Don't forget the lube!
Zen Chameleon is offline   Reply With Quote
Old 06-25-2011, 11:37 AM   #3 (permalink)
Evanguy's Avatar
Rep Power: 4 Evanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow upEvanguy is about to blow up
if you really searched you would have noticed that there is like 7 parts that most every mini me uses.
you will need the same parts for any mini me setup. so both of these right ups will work for you
FAQ: D15 SOHC VTEC Mini-Me : Massive Write-Up (56k Goodbye) - Honda-Tech
[FAQ] D16Y7 / Y8 MINI-ME WRITE-UP.... WITH PICS (56k, maybe not) - Honda-Tech
vtec- Head
non vtec- Block
Ecu- for the head your using
Distributor- for the head your using
Intake Manifold- for the head your using
Headgasket and timing belt- for which ever head you choose to use
OBD1 Injectors, if converting...
I'm so JDM, i sleep on the right hand side of my bed
WTB: 1 forged piston http://www.d-series.org/forums/want-...ml#post2963890
My NA D17Y8 build http://www.d-series.org/forums/showc...ml#post2525188
Evanguy is offline   Reply With Quote
Old 06-25-2011, 12:17 PM   #4 (permalink)
89c1vicdx's Avatar
Is there a way I can do the vtec an still use my dpfi intake??
Old 06-25-2011, 12:39 PM   #5 (permalink)
Evanguy's Avatar
i think so, you would have to use a dpfi ecu and get it chipped and converted into a vtec ecu(not to sure about this i just heard of it) and once it was chipped you could get it tuned because the stock maps will probably be no good for the motor you just built.
way easier to just use a D16Z6 Head, Dizzy, Ecu, Intake manifold, throtel body and fuel rail
just find a complete z6 head
Honda D-Series Compression Calculator by ZealAutowerks
use this^^ to figure some things out about comp and what head would be the best for you and if your going to rebuild the bottom end this will help with your piston choise
Old 06-25-2011, 12:52 PM   #6 (permalink)
89c1vicdx's Avatar
Oh ok can I use my stock wiring harness an just add the extra wires??
Old 06-25-2011, 12:57 PM   #7 (permalink)
Evanguy's Avatar
yeah it should be a few wires for MPFI and then 2 for vtec to work.(1 for vtec solenoid and 1 for oil pressure sensor)
if your unsure of what your doing you can just convert your car to MPFI befor you do the head swap so its just one thing at a time and if you run in to problems it will be easier to figure out where yoou went wrong. once you get MPFI working then do the head swap you seem pretty new at this its probably your best way of doing it
Old 06-25-2011, 01:01 PM   #8 (permalink)
89c1vicdx's Avatar
Lol ya just at doin the swap lol iv rebuilt engines an stuff but nothin like this ya I think I will do the dpfi to mpfi swap first. Will I be able to use my header for the d15 since I just put it on like 2 days ago
Old 06-25-2011, 01:03 PM   #9 (permalink)
89c1vicdx's Avatar
Oh an doin the mpfi swap can I use my stock ecu till I do the mini me?
Old 06-25-2011, 01:08 PM   #10 (permalink)
Evanguy's Avatar
not sure but i really dont think so since its set up for only 2 injectors not 4. but i have no clue thats just a guess.
Old 06-25-2011, 01:10 PM   #11 (permalink)
89c1vicdx's Avatar
oh ok I'll do more research on it than lol what u drive
Old 06-25-2011, 02:04 PM   #12 (permalink)
baajaa's Avatar
Rep Power: 4 baajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eaglebaajaa is fly like an eagle
vtec- Head
non vtec- Block
Head studs for the head you use is also nessasary. Contact arp , describe what you are doing, and order your studs. Studs are better than bolts any fay of the week.
Im sure, but why would you want to do that if the other intake and fuel delivery system is superior?
Yes, but using the factory harness for that particular head is not only easier, but more reliable. Unless your a wiring wizard.
The bolt patterns are the same. So yes.
I would assume not. The factory ecu is set up for two injectors. You could add two more, by splicing the wires.. but your injector output would be half of what it should be. So your injectors will be flowing half of what they should. This is in no way fact, because I haven't searched it. Im just using my own personal knowledge of ohm's and electrical resistance to form a non-factual conclusion.
My personal opinion..
Get a complete z6 head including throttle body, injectors, all sensors and intake manifold.
Get the complete z6 wiring harness.
z6 stock ecu (p28. ), chip it. Load up a stock basemap. Crome comes with a stock z6 map, so downloading the program and uploading the bin file is all you have to do.
Arp headstuds for better reliability.
headgasket. Preferably a mls one.
Get an adjustable cam gear, so you can set the mechanical timing perfectly.
Cool air intake.
Take car to a tuner, or tune it yourself after you do some research.
This isn't nessasary, but I recommend it..
have your head completely cleaned, and have all seals replaced.
deck it for flatness.
Have the intake ports worked over so all casting bumps and marks are removed.
Do the same to exhaust, but polish it.
Polish combustion chambers.
Call up delta, and get a 272 regrind on your cam.
That all must be done before head is installed for the first time. So you only have to tune it once.
Personal opinions, nothing more.
goodluck on your build buddy.
easy answer, pump and dump, just wrap your PTO shaft!
baajaa is offline   Reply With Quote
Old 06-25-2011, 02:04 PM   #13 (permalink)
Evanguy's Avatar
i drive a bone stock 91 ef hatch SI. right now......had others will have others, a few projects on the go. I JUST LOVE EF HATCHES more then any other cars on the road (for under $100k)
Old 06-25-2011, 02:09 PM   #14 (permalink)
BryanK20's Avatar
Rep Power: 7 BryanK20 is learning the way of the DBryanK20 is learning the way of the D
no you cant use the DPFI ecu when converted to MPFI. You need the PM6 ECU and a Si (A6) distributor as well
1995 Civic EX
BryanK20 is offline   Reply With Quote
Old 06-25-2011, 02:21 PM   #15 (permalink)
89c1vicdx's Avatar
Ah I see thanks baajaa an ya the hatchbacks are nice but I like the 4dr civics a lil more I have a 89 civic dx just put 4-2-1 header an test pipe on the other day to go along with my exhaust but it seems to idle a lil diff is that normal? Its not idlin rough or missin it just sounds diff when idles but has a lot better throttle response
Old 06-25-2011, 02:30 PM   #16 (permalink)
89c1vicdx's Avatar
An the a6 dist will mount onto my b2 head? Will I need to change plugs an wires to than?
Old 06-25-2011, 04:35 PM   #17 (permalink)
89c1vicdx's Avatar
Well gotta work if anyone has anymore good info an advice email me at kottonmouth2009@gmail.com thanks for the help guys
iconAll times are GMT -8. The time now is 06:26 AM. | Welcome to Forum, please register to access all of our features.
