Automatic to Manual ECU Conversion - D-series.org
Old 11-11-2003, 06:53 PM   #1 (permalink)
JDMd15b
I did a JDM d15b swap in 96 civic a while back, and ordered a p28 ecu. They sent me an automatic, which was fustrating because i cant send it back. I ordered another one from a different source, and was sent another automatic. I tried for a manual one last time, and was sent ANOTHER fucking automatic p28. My first question is this: Can i run this ecu in my 5spd without major problems?? My second question is:Can i turn my automatic p28 ecu into a manual?? I already checked pgmfi.com and was unable to come up with much. Any help would be greatly appreciated
Old 11-11-2003, 11:11 PM   #2 (permalink)
makku's Avatar
Rep Power: 18 makku is a Top Aussie
makku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussie
I don't know the answer to your question but next time check the serial number on the ECU if there's a picture. After the p28 there is a long number followed by AXX. If it's A0X (X is any number), it's a manual. If it's A5X, then it's automatic.
If you already knew this, then ignore my post
makku is offline   Reply With Quote Quick reply to this message
Old 11-26-2003, 07:59 PM   #3 (permalink)
paaascal
mines ARJ and its auto lol looking for a manual too
Old 11-27-2003, 01:00 PM   #4 (permalink)
DOG
DOG's Avatar
Rep Power: 16 DOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatnessDOG is approaching greatness
iTrader Score: 18 reviews
Check out the Hondata site. Im pretty sure they can convert it.
http://www.hondata.com
look over there site they have tons of info there and if you cant find it email them. They have a pretty good customer service.
DOG is offline   Reply With Quote Quick reply to this message
Old 11-27-2003, 02:02 PM   #5 (permalink)
sqmark
In the bottom right of the ECU (conecter to the left) there is a row of resistors. Cut out RP17 and RP18 and solder a piece of wire across RP17. BINGO.. One manual ECU, Don't worry fuel and ignition they use the maps.
Old 11-27-2003, 03:32 PM   #6 (permalink)
No more Honda's :-(
FMYStreetRacer's Avatar
Rep Power: 15 FMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to allFMYStreetRacer is a name known to all
it's that simple to convert to manual? i always thought that you had to chip it? oh well i guess that i just got lucky, i have a manual p08 in my car.
97 Cherokee SE, 3" Lift, 31x10.50's on soft 8's
83 RX-7 Wide Body, 4-port 13B street-ported, Cartech turbo system with blow through carbs
03 Kawasaki KLX400R tagged
FMYStreetRacer is offline   Reply With Quote Quick reply to this message
Old 11-27-2003, 03:47 PM   #7 (permalink)
DOG
DOG's Avatar
http://www.hondata.com/techecuanatomy.html
OBD I ECU Anatomy
Old 11-27-2003, 03:50 PM   #8 (permalink)
No more Honda's :-(
make it bigger. i can barley see. this looks like a good pic to save and keep around.
Old 11-27-2003, 09:56 PM   #9 (permalink)
paaascal
did so, eror code 19 still comes out and check eng still on!
part no 37820-p08-900
461-145-992
ARJ
numbers on the board....
denshigiken
in 4 rectangle
123467b? 0 2 wxyz 1234??
90ab
T3J-D
02D01550-1500
Old 11-27-2003, 10:14 PM   #10 (permalink)
DOG
DOG's Avatar
Did you reset your ecu?
19 Automatic transmission lockup control valve
Old 11-27-2003, 10:24 PM   #11 (permalink)
paaascal
well the ecu was unplugger for 15 mins the time it took me to remove the resistors and weld the wire...
Old 11-29-2003, 10:31 PM   #12 (permalink)
spoonbender's Avatar
Rep Power: 14 spoonbender is trying to make new friends
i would also like to add that any and all honda/acura ecu's ending with 900/901 are also automatic!!! i never new that a5x was auto though???
spoonbender is offline   Reply With Quote Quick reply to this message
Old 11-30-2003, 08:21 AM   #13 (permalink)
No more Honda's :-(
in 88-91 ecus (PM6, PR4, PW0, PR3, PM7):
5spd = 000, 001, 002, A00, A01, A10, J00, J001, C01, C00
Auto = J51, J50, A50, A51, 900, 901, A60, C50, C51, X30, A80
92-5 ECUs (P28, P30, P61, P72, P91, P0
5spd = 000, 001, 002, 003, A00, A01, A02, C00, C01, C02, J00, J01, J02
Auto = J50, J51, 900, 901, 902, C50, C51, C52, A50, A51, A52
96-00 ECUs (P2E, P2P, P2J, P72)
5spd = 000, 001, 002, 003, A00, A01, A03, C00, C01, C02, C03, J00, J01, J02, A11, C11
Auto = A70, A71, A72, A91, A92, C70, C71, C72, C91, C92
from the patterns we can learn the following:
first letter = country of orgin
J = Japan
C= Canada
A=USA
second digit, if 5, 7, 9 then ecu is auto usually
third digit denotes the version/variation
iconAll times are GMT -8. The time now is 09:24 AM. | Welcome to Forum, please register to access all of our features.
