Setting proper timing using timing light (adj. cam gear and milled head) - D-series.org
Old 05-29-2010, 07:58 PM   #1 (permalink)
Rep Power: 0 vtec8200rpms is trying to make new friends
Default Setting proper timing using timing light (adj. cam gear and milled head)
I have a d16y8 block with a d16z6 head. I sent the head to be milled 0.040" and when I got it back I realised the head had been milled a good amount before, at least 0.020". After I put it on my block I used my oem z6 cam gear. The car was very slow below 4000 and pulled hard all the way to the rev limiter. I maxed out my timing on my distributor and the car ran better, but still was very sluggish below 3000 rpms. I grinded the holes on my distributor to advance it a bit more and car pulls hard, ran 15.1 @ 89 mph in a 4 door EF but I feel it isnt at its best.
I figured the best way was to get an adjustable cam gear and strobe light to check timing. I have an adjustable cam gear from 96-00 and a base model strobe timing light. I know I have to advance the cam gear 4.75'' to compensate for the difference between z6 and y8 cam gear.
How do I set correct cam timing with my strobe light?
do I have to loop the connector on the passenger side under the dash?
I have access to these manuals but it doesnt show, anybody has a link to better manuals?
http://files.clubcivicquebec.com/Man...ice_Manual.pdf
thanks
vtec8200rpms is offline   Reply With Quote Quick reply to this message
Old 05-30-2010, 07:38 PM   #2 (permalink)
anyone?
Old 05-30-2010, 07:39 PM   #3 (permalink)
Rep Power: 15 lkailburn It's a JDM Star Bitches....
are you asking how to use the timing light or what timing to set for your specific motor setup?
-Luke
y7 block, deburred Vitaras/FJT Ibeams, Stg4 P&P y8 head, ported and matched y8 IM, ITR tb, wrx urboTurb, ramhorn, jrc 5" fmic, 450's, 2.5" dp, 3" exhaust, clutch specialties stg2, act 12lb, rebuilt y8 tranny, S300. 221whp/201wtq
2005 Legacy GT
My D16 Build
lkailburn is offline   Reply With Quote Quick reply to this message
Old 05-30-2010, 07:48 PM   #4 (permalink)
how to use timing light to set my specific motor setup.
Old 05-30-2010, 07:48 PM   #5 (permalink)
racer76j's Avatar
Rep Power: 8 racer76j is almost a somebodyracer76j is almost a somebodyracer76j is almost a somebodyracer76j is almost a somebody
You have to get the mechanical timming correct .then do your spark time.Without knowing how much was taking of the head exactly you can only guess at what to set your cam gear at.Maybe try a search to see where the stock cam is degreed at and degree your cam.That will set your base time correct.Then you ignition timing can be set by light.If not search and find how many deg is changed in mech timming per thou of an inch milling.And set your gear from there.Good luck.
racer76j is offline   Reply With Quote Quick reply to this message
Old 05-30-2010, 07:52 PM   #6 (permalink)
Thank you for the information.
So the only way to set proper mechanical timing is by degreeing or can I ''guess'' it and check it with my timing light then make adjustments?
Old 05-30-2010, 07:56 PM   #7 (permalink)
racer76j's Avatar
search man.Theres a number for how many degreees for thous off milling that your cam timming changes.
Old 05-30-2010, 07:58 PM   #8 (permalink)
racer76j's Avatar
One threads enough btw
Old 05-30-2010, 08:34 PM   #9 (permalink)
B20BbenN's Avatar
Rep Power: 12 B20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropesB20BbenN is starting to learn the ropes
thanks
y8 cam w/ z6 sprocket, z6 cam w/ y8 sprocket
You need to retard the 96-00 adjustable camgear, your setup is basically a Z6 head with a Y8 adjustable camgear....
First, adjust the camgear timing, second adjust ignition timing!
Check the Page 23-105 of the 96-00 service manual to adjust the ignition timing!
B20BbenN is offline   Reply With Quote Quick reply to this message
Old 04-16-2015, 08:27 PM   #10 (permalink)
Rep Power: 0 Chiboy602 is starting to piss people off
I know this is a really old post but I'm trying to figure out pretty much the same thing. I have a z6 block I'm putting a y8 head on. I have the y8 cam and a vms adjustable cam gear from ebay that says it's good for the d16z6 and d16y8. I'm trying to figure out what to set the adjustable cam gear too? Any help is appreciated!
Chiboy602 is offline   Reply With Quote Quick reply to this message
Old 04-17-2015, 05:14 AM   #11 (permalink)
92CXyD's Avatar
Rep Power: 12 92CXyD is hot as a volcano92CXyD is hot as a volcano
Start at 4.5deg advance, just like the upper right hand diagram in the cam timing post above.
If the block or head has been milled then advance ~1 deg/ 0.012" milled.
That will get the closest, degreeing the cam would be a good idea it is not a stock y8 cam.
If you want to know about my avatar
ENMO.
An Emo car would cut its own tires and never get out of the garage.
92CXyD is offline   Reply With Quote Quick reply to this message
Old 04-17-2015, 05:49 AM   #12 (permalink)
Never finishes (TWSS)
Evanguy's Avatar
Rep Power: 15 Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!Evanguy is the fucking MAN!!!!
Its one degree per mm or 39 thou. Hence the 5 mm difference on d15 blocks need 4.75*
Omg the guy who bumped this thread is fucked. I told him what he need. He has a y8 snd a d16 block he needs a y8 cam gear to go with his y8 cam. he doesnt know enough to argue. For fuck sakes.
Also i already explaned to you about your gear.ok it fits on a 88-00 cam but the 96-00 cams are keyed differen... so the marks for your cam are set around a 88-95 cam. So to use it with a 96-00 you need to set it advanced 4.75* witch in turn makes the adjustable cam gear a oem y8 gear. Witch is what you need. You match the cam with the cam gear unless you are changing deck heighs of your block.
This is too simple. Its been covered 3500 times. Why would you need an adjustable gear? Answer that please. Once you know why you use one you will understand why you dont need one. Stop posting shit. Your reading threads from 2009. If it isnt from 2013 keep searching. All this have bee covered corectly in the last two year more then 500 times. I know for a fact i answered this 65 times in the last six konths.
Forget you have a z6 block its the same fucking thing as all sohc blocks. You cought up on the wrong thing. The block is the same as a y8 and a6 but with different dip stick locstion and knock sensor. Why the fuck do you need an adjustable cam gear if only the dipstick and knock sensor are different?
d17y8 custom ITB's, NA HP build
homemade small IC engine
homemade alu rods pistons
Old 04-17-2015, 07:12 AM   #13 (permalink)
Rep Power: 50 slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !slo_eg8 is on a level you can only DREAM about! ! !
thank you for this. now, find my thread where I jump out of a window and paste it there lol
totaled. 93 EJ2
NEW 95 ej1
d16y7 block with z6 head
y7 transmission
ls meshies, oem wing, blacked out tails with h.i.d head lights
Old 04-17-2015, 07:58 AM   #14 (permalink)
Evanguy's Avatar
The guy who bumped this five year old thread is the same guy who started the other thread. Im sure he will see it lol
Old 04-17-2015, 07:59 AM   #15 (permalink)
no, I mean the guy who has a z6 head and doesn't know what bottom end to use. the same guy that offered DOUBLE to someone to check their engine, and if it was good, he'd buy it
totaled. 93 EJ2
NEW 95 ej1
y7 transmission
Old 04-17-2015, 08:11 AM   #16 (permalink)
Evanguy's Avatar
Ohh yeah. Lol that guy, who cant find a dseries for under 1000$ because he doesnt know what he need or wants lol. Yeah this info would have helped him haha. Even though you sent him 20 listing for motors close to him lol
Old 04-17-2015, 09:21 AM   #17 (permalink)
Rep Power: 101 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
1/2 way in the forest or 1/2 way out????
Same thing for 1/2 tooth error.
I know I tried so many different ways to figure it out, I never loosen then timing belt tensioner.
transzex is online now   Reply With Quote Quick reply to this message
iconAll times are GMT -8. The time now is 06:08 PM. | Welcome to Forum, please register to access all of our features.
