Carbon Build Up - D-series.org
Old 01-21-2010, 10:50 PM   #1 (permalink)
Rep Power: 0 daygobaker is starting to piss people off
Default Carbon Build Up
Is there really a chemical out there that dissolve carbon build up. I used the acetone/atf fluid, seafoam and diesel to try to clean carbon build up...None did anything when submersed.. Does it need to have heat to work, like a seafoam treatment or something? I see all those ads where they clear all that carbon build up, like the ones with valve comparisons, you know the one from shell...but shit, I have first hand experience with "chemical treatments" just doesnt work....easy off works, but leaves metal all black and tarnished, if left too long...
daygobaker is offline   Reply With Quote Quick reply to this message
Old 01-21-2010, 10:57 PM   #2 (permalink)
amperu's Avatar
Rep Power: 24 amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !
amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !amperu is on a level you can only DREAM about! ! !
z-max.
I've got Super Street taste and an eBay budget!
Amperu is fucking winning. Hard.
Is there anything you aren't badass at? Lol
RIP - patprimmer
amperu is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 12:30 AM   #3 (permalink)
Rep Power: 100 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
Berryman's Chem Dip.
What are you trying to clean?
There is only one chemical that LOVES carbon, it is NASTY as well.
Berryman's B9 Chem Dip
Because of the chemical make up of this product, which contains Methylene Chloride and Cresylic Acid, disposal must conform to the rules of your community for proper disposal of Hazardous Waste. To prolong this disposal and reduce the amount of chemical, several of our customers use the spent product as a "pre-rinse" to use before dipping into a new bucket of Chem Dip. This allows the part to soak up a little of the spent solvent, which pre-softens some of the residual material on the part.
Proper storage of Chem Dip is also a very important situation. Because of the high Di-electric chemistry, some discharge "electrolysis" may result from storing directly on concrete or on a metal rack staged on concrete.
Old 01-22-2010, 12:47 AM   #4 (permalink)
swich's Avatar
Rep Power: 11 swich is starting to learn the ropesswich is starting to learn the ropesswich is starting to learn the ropesswich is starting to learn the ropesswich is starting to learn the ropesswich is starting to learn the ropes
carb cleaner... take a while... spray on and leave it. come back 30 min spray again. the carbon bond to the metal breaks down the the carbon flacks off.
or a wire brush but be carful with that...
Swich: the sound i make as i pass your slow ass
Slow but still in front of you.
Speed Kills...Be Careful...Drive a EG
swich is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 10:13 AM   #5 (permalink)
kermitt's Avatar
Rep Power: 8 kermitt is learning the way of the Dkermitt is learning the way of the D
I did the same when i rebuilt/ported my head but i used brake cleaner, it's a little stronger than carb cleaner
Works great for Cat and Dog pee also.
kermitt is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 04:20 PM   #6 (permalink)
i dunno, just curious because i couldn't get the carbon out from the valves and the pistons...i thought seafoam was suppose to be strong stuff...so i figured there was really nothing out there besides a chem dip or something...
Old 01-22-2010, 04:22 PM   #7 (permalink)
can the chem dip be sprayed on the composite head gaskets?
Old 01-22-2010, 06:34 PM   #8 (permalink)
EJ6Civic27's Avatar
Rep Power: 12 EJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to all
iTrader Score: 17 reviews
I used the cheap $1/bottle of degreaser from the Dollar Store. Let it sit for about half hour, and hit it with boiling hot sink/faucet water, and it took the carbon off of my 120k mile y7 head.
a6 Cam/z6 intake manifold/full header back exhaust
Spider RPM tune/3500rpm launch/7200 fuel cut/NGK AFX Wideband
EJ6Civic27 is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 11:40 PM   #9 (permalink)
90civicfl's Avatar
Rep Power: 9 90civicfl smells like Borat90civicfl smells like Borat90civicfl smells like Borat90civicfl smells like Borat90civicfl smells like Borat
Haha switch you make it look like an infomercial. BAM! it takes a lil time but they will come clean with a good degreaser and a lil scrubbing
90civicfl is offline   Reply With Quote Quick reply to this message
Old 01-23-2010, 12:40 PM   #10 (permalink)
swich's Avatar
grrr no "T" swich(say it like swish) but yeah i try hard to help ppl out when i can. lol
Old 01-24-2010, 08:13 PM   #11 (permalink)
90civicfl's Avatar
my bad on the name mixup. but i've got my head off right now and it sure nough took more work than those pictures reveal to get it clean lol.
Old 01-25-2010, 12:43 AM   #12 (permalink)
eg_coupe's Avatar
Rep Power: 0 eg_coupe is nobody
x2 for brake kleen.
d16z6 75.5mm block
-bored .5mm, decked .0010
-head decked .020
-ycp vitara 75.5mm pistons
-fjr-spec extended I beam rods
-cometic headgasket
-arp rod/headstuds
-notched block and girdle
-micropolished crankshaft
eg_coupe
eg_coupe is offline   Reply With Quote Quick reply to this message
Old 01-25-2010, 04:15 AM   #13 (permalink)
swich's Avatar
carb cleaner and 6 days of spraying it when i could. it take about 95% off. but the rest wire brush.
but if you porting the head. just start sanding with 200 grit
iconAll times are GMT -8. The time now is 08:01 PM. | Welcome to Forum, please register to access all of our features.
