EK1 D16Y6 engine needs your help for turbo build - D-series.org
Old 11-01-2009, 08:17 AM   #1 (permalink)
D16Y6's Avatar
Rep Power: 0 D16Y6 is nobody
Default EK1 D16Y6 engine needs your help for turbo build
Hi dears
this my 1st post in this forum and i hope find knowledge answers here.
Actually I have honda civic hatch 1996 with D16Y6 (I know you will suprise about ths type of engine) SOHC VTEC 1.6L
since one year I have boosted my stock engine with TD04E turbo to 14psi and it was fantastic and smooked SIR sedan with B18C Integra Type-R swap.
You already know this amount of boost will kill my stock engine and that what actually happend. its start producing huge white smoke like cloud from muffler and increase in temp. and finally I heard cracking sound (tak tak tak) from the engine with bad firing. So I am planning to upgrade my engine for turbo application and I need my engine to hold up at least 18-20psi boost.
can you just help me on which appropriate parts will be best fit to D16Y6 engine. I saw over the ebay vitara pistones for D-series turbos size 75 mm and Compression 8.5:1 check this linkPistones kit
what els do I need for block and head upgrade??
If you need to know more about D16Y6 in order to help you research i can provide you with spec. as per Repair_Manual
Name:	D16Y6 spec1.JPG
ID:	22328   Click image for larger version
Name:	D16Y6 spec2.JPG
ID:	22329   Click image for larger version
Name:	D16Y6 spec3.JPG
ID:	22330   Click image for larger version
Name:	D16Y6 spec4.jpg
D16Y6 is offline   Reply With Quote Quick reply to this message
Old 11-04-2009, 07:58 AM   #2 (permalink)
D16Y6's Avatar
up up
Old 11-04-2009, 10:35 AM   #3 (permalink)
snailslow's Avatar
Rep Power: 16 snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!
snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!snailslow is the fucking MAN!!!!
if your on a budget like i am, do the vitara's with eagle rods..what im doing. i went with 75.5mm .20 bored on stock sleeves
snailslow is offline   Reply With Quote Quick reply to this message
Old 11-06-2009, 12:47 PM   #4 (permalink)
D16Y6's Avatar
hi thanks for your replay
i found on ebay this pistons piston&rod i think its what you mentioned.
i have found clutch kit F1
is there nessary upgrade for head that i need for my build?
Old 11-06-2009, 12:49 PM   #5 (permalink)
D16Y6's Avatar
.20 bored
what is this ?
iconAll times are GMT -8. The time now is 05:41 PM. | Welcome to Forum, please register to access all of our features.
