D16y8 with ZC pistons - D-series.org
Old 09-27-2009, 08:32 PM   #1 (permalink)
rex-d16y8's Avatar
Rep Power: 0 rex-d16y8 is nobody
Default D16y8 with ZC pistons
Thinking bout putting p29 ZC pistons in my y8....bringing it to the shop...was woundering if i would need to change my rods,or any thang eles???
rex-d16y8 is offline   Reply With Quote Quick reply to this message
Old 09-27-2009, 08:34 PM   #2 (permalink)
Poop Sock
wizard's blood's Avatar
Rep Power: 24 wizard's blood Still a JDM Star....
wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....wizard's blood Still a JDM Star....
iTrader Score: 34 reviews
Send a message via AIM to wizard's blood
no. you will need to convert to obd1 and tune though.
DD: 07 wrx stg2
wizard's blood is offline   Reply With Quote Quick reply to this message
Old 09-27-2009, 09:00 PM   #3 (permalink)
rex-d16y8's Avatar
yea my y8 is covet to odb1....and i found a site to calulate my compression ratio SolBlu's Helpful Del Sol Site....it said 13.1 which i know is not a daily driveable....but it there any thang eles i sould know before i put the ZC pistons in???
Old 09-27-2009, 09:03 PM   #4 (permalink)
Tibby's Avatar
Rep Power: 19 Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!Tibby is the fucking MAN!!!!
dont soak the bearing in lube lol like someone did
ak riding shotgun literally
autox/ touge ej1
Built 12.5 d., ac, pic selects, itr sway, wide wheels, more bracing than a dentist office lol
09 Chevy 3500hd crew cab long bed 4x4 just because I felt like it
Tibby is offline   Reply With Quote Quick reply to this message
Old 09-27-2009, 09:03 PM   #5 (permalink)
Thewall's Avatar
Rep Power: 12 Thewall is hot as a volcanoThewall is hot as a volcano
Holy hell thats high. If you can't run on 101 or E85 I would def. suggest the z6 head. IMO the y8 combustion chambers are to small. Or maybe find a .05" HG and that will lower the comp lol.
Thewall is offline   Reply With Quote Quick reply to this message
Old 09-28-2009, 04:11 PM   #6 (permalink)
lovinhonda-97dx's Avatar
Rep Power: 10 lovinhonda-97dx will become famous soon enoughlovinhonda-97dx will become famous soon enoughlovinhonda-97dx will become famous soon enough
damn thats high..let us know how it works out
lovinhonda-97dx is offline   Reply With Quote Quick reply to this message
Old 09-28-2009, 07:33 PM   #7 (permalink)
rex-d16y8's Avatar
yea i gonna put a thick hg on it to drop the compression...hoping to at least drop it to 12.8 and see how that works out for me...i'll post it up once it's done....thanks
Old 09-28-2009, 07:44 PM   #8 (permalink)
Thewall's Avatar
Well according to Zeal, your comp should be around that 12.6. Just remember your going to need high octane. I think that comp is just ridiculous. You should just go with the pg6 pistons, that will give you 12.2cr which is way better imo. Thats with the stock HG.
Edit: I just checked the comp. calc. you used...and I think its crap lol. Your elevation also effects the "effective cr".
Old 10-01-2009, 01:21 PM   #9 (permalink)
The_Acid_Beaver's Avatar
Most of y'all are retarded.
P29s in a Y8 will make youre tuning life hell. The Y8 head is designed to use pistons with high quench pistons, which you don't have with the P29s. Also, the very compact combustion chamber of the Y8 will be split, causing crap combustion. Most P29/Y8 builds have to have so much timing pulled, they don't make much power over stock. That combo is very knock limited. Don't do it.
Use PG6 pistons if you want to bump up your compression. You'll actually be able to use 93 octane to not detonate your pistons to death.
RTFM. No, really. Do it.
Old 10-01-2009, 02:07 PM   #10 (permalink)
cervan's Avatar
p29 in y8 = cracked ring lands.
1990 crx - 12.2 @ 119mph Sold
Old 10-01-2009, 03:29 PM   #11 (permalink)
Thewall's Avatar
You don't need to be an ass. Sorry we all (y'all isn't a word) didn't know that....
Old 10-01-2009, 03:48 PM   #12 (permalink)
noob
z6civicex's Avatar
Rep Power: 13 z6civicex It's a JDM Star Bitches....
z6civicex It's a JDM Star Bitches....z6civicex It's a JDM Star Bitches....z6civicex It's a JDM Star Bitches....z6civicex It's a JDM Star Bitches....z6civicex It's a JDM Star Bitches....
iTrader Score: 31 reviews
The_Acid_Beaver knows what he is talking about.....there are only a few people on this site i would listen to and he would deff. be one of them.
SAVE THE SOHC
Instagram:z6civicex
Fueltuckd.com
z6civicex is offline   Reply With Quote Quick reply to this message
Old 10-01-2009, 03:53 PM   #13 (permalink)
Right, but, if you would f'ing search, it's been covered.
And, for the record, I can type me some proper English, but, I don't always do it. Stop taking things on the interwebs so seriously. Seriously, check this out: If you have to ask yourself "Am I retarded/stupid/moronic/imbecilic/dense?," the answer is almost always invariably an emphatic "YES!"
For the record, I am also a retard, but about different things but not about the fact that P29s suck, ESPECIALLY in a Y8. That's just a fairly well established fact that has been substantiated by some of the best tuners in the country. It has also been proven that you can easily use 87 octane at over 12.5:1 SCR. (If you pay attention to the combustion chamber and can tune well.)
Old 10-01-2009, 07:12 PM   #14 (permalink)
Thewall's Avatar
I wasn't saying he didn't...Just that I didn't lol.
Why would I need to search? I have a z6 and all I was trying to do was give him the little knowledge I knew. I'm not going to lie...I'm retarted when it comes to the Y series, I had no idea that the p29's would be that much of a problem in the y8, but I learned. I just don't appreciate unnecessary "name" calling. I don't think I took it that seriously, I'm not pissed...just demeaned lol. Anways...Good info hahaha
Old 03-30-2010, 11:36 AM   #15 (permalink)
Rep Power: 8 boosteddohczc is nobody
well i know im new to this site but i have built alot of d series with the p29 pistons and tuned them just fine but i wouldn't use a y8 head. If i was you id find a z6 head, it flows better and has a better combustion chamber for high compression. You will end up with a little over 12.1 compression and will run fine on 93 if you have a good tune. ya you have to pull some timing out but it can be done easaly and will make good power but a cam and porting it will help alot too
boosteddohczc is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 11:58 AM   #16 (permalink)
fuse's Avatar
Rep Power: 9 fuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regularfuse is obviously a regular
pg6 pistons get my vote. Acid beaver loves the word quench........ Nice check out my post count 666 ftw.
Neptune dealer, Crome dealer, turbo edit, bre, nistune, street tunes, dyno tunes, ecu chipping obdo and obd1, ecu repairs, no basemaps, homemade conversion harnesses, homemade led gauge clusters, in co springs. Chips In stock ecus in stock with trade in discounts. Email
or pm
fuse is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 12:03 PM   #17 (permalink)
CR-Vtakin
Levi's Avatar
Rep Power: 44 Levi is on a level you can only DREAM about! ! !Levi is on a level you can only DREAM about! ! !Levi is on a level you can only DREAM about! ! !Levi is on a level you can only DREAM about! ! !
Send a message via AIM to Levi Send a message via MSN to Levi
btw. y'all is a word.
1993 D16Z6 Civic Turbo 230hp 218tq *sold*
1996 Acura Integra LS Sedan
Laying Claim To My Own Thread:
1996 Integra Project Car:
Levi is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 12:10 PM   #18 (permalink)
Thewall's Avatar
Cool, now know. I also had no idea how retarded I sounded in these posts, so my apologies lol.
Old 03-30-2010, 12:26 PM   #19 (permalink)
Black91CRXsi's Avatar
Rep Power: 33 Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !
Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !Black91CRXsi is on a level you can only DREAM about! ! !
iTrader Score: 17 reviews
Especially here in the dirty south!
91' CRX Si All motor A6 running 14.67@93.87mph (old build).
14' Accord Sport 6spd, K-sports, 19" TSW's, K&N typhoon and Borla axle back
"I don't want it. I just need it. To feel, to breathe, to know I'm alive."
R.I.P - Pat Primmer
Beat them, cheat on them, treat them like shit and you'll get a hot woman that won't ever leave you. Women are a stupid breed that don't use fucking sense.
Black91CRXsi is offline   Reply With Quote Quick reply to this message
Old 03-30-2010, 04:23 PM   #20 (permalink)
cervan's Avatar
actually y8 has a better combustion chamber for high compression its just hard to find a piston that doesnt increase the compression so dramatically with the y8 head. The z6 only out flows the y8 at high rpm's (but they are very very close to one another were not talking massive differences)
With a massive duration and lift cam you will be able to get your dynamic compression down but without that dont even try messing with that much compression. Even 12:1 is tipping the scales on stock equipment even with a good tune. BTW, if your going to run anything over 12:1 and still want a streetable car then you probibally will need to go vtec, without vtec it will be very hard to keep the dynamic compression down with a large lift/duration cam without having a large lope and alot of breaking up in the low end.
iconAll times are GMT -8. The time now is 01:27 AM. | Welcome to Forum, please register to access all of our features.
