Valve adjustment on a d16 z6 - D-series.org
Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » Engine Building
Old 06-29-2009, 09:18 AM   #1 (permalink)
Rep Power: 0 cardinalredeg is nobody
Post Valve adjustment on a d16 z6
hey i new here just bought a d16z6 went to put it in my g/f car timing was off and i believe that the valves needs to be adjusted i dont have a manual that tell u everything kinda straped right now between both cars but i need d-series.org to give me a hand is this true
at tdc all valves on cylender 1 are closed go another 90 then all valves on cylender 3 are closed is this true thanx for any help
cardinalredeg is offline   Reply With Quote
Old 06-29-2009, 09:33 AM   #2 (permalink)
5th gen's Avatar
Rep Power: 0 5th gen is nobody
go tdc on the camgear, and the valves for cylinder #1
would be closed you can adjust those valves,
you then turn the crank pulley 180*
or have the camgear rotate 90* (same thing)
and repeat on cylinder #3 the rotation goes 1,3,4,2,
good luck on adjusting and yeah,
b17---- blown
lsvtec--- blown
mini-me--- blown
d15 block y8 head y7 internals--- teh sex
5th gen is offline   Reply With Quote
Old 06-29-2009, 09:35 AM   #3 (permalink)
Twistease's Avatar
Rep Power: 6 Twistease will become famous soon enoughTwistease will become famous soon enoughTwistease will become famous soon enough
http://d-series.org/forums/diy-forum...tml#post814552
Twistease is offline   Reply With Quote
Old 06-29-2009, 09:47 AM   #4 (permalink)
Post
thanx for the quick response are the intake .007
Old 06-29-2009, 09:48 AM   #5 (permalink)
Post
Old 06-29-2009, 10:09 AM   #6 (permalink)
mightyjoecivic's Avatar
Rep Power: 17 mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!
mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!mightyjoecivic is the fucking MAN!!!!
.007 Intake and .009 Exhaust, Firing order is: 1,3,4,2. Adjust your valves using the firing order and you cant go wrong. :td:
1993 Ford Cobra #1252 of 4993-- Bone stock
Tuning, the other bolt-on.
**Insert 95' 4dr civic...soon**
mightyjoecivic is offline   Reply With Quote
Old 06-29-2009, 10:13 AM   #7 (permalink)
Post
Old 04-10-2012, 07:03 PM   #8 (permalink)
Rep Power: 0 95EGSiHatch8807 is nobody
Hey there noticed this is a pretty old thread but I am about to adjust valves on my z6 as well and I am wondering about engine temp I have been looking around and some forums say its best to do first in the morning when engine is very cold and others say to just let the engine cool for about a hour or so?? Just curious if it really attests?
95EGSiHatch8807 is offline   Reply With Quote
Old 04-10-2012, 07:04 PM   #9 (permalink)
Matters^^ stupid auto correct.
Old 04-10-2012, 07:31 PM   #10 (permalink)
Scott53092's Avatar
Rep Power: 2 Scott53092 is starting to learn the ropesScott53092 is starting to learn the ropesScott53092 is starting to learn the ropesScott53092 is starting to learn the ropesScott53092 is starting to learn the ropesScott53092 is starting to learn the ropesScott53092 is starting to learn the ropes
As long as the actual engine is less than 100* F, then you are good to adjust. with heat everything expands, so if you adjust them with the engine too warm, once it cools down it'll be way too loose when cold.
Scott53092 is offline   Reply With Quote
Old 04-10-2012, 07:58 PM   #11 (permalink)
Alright thanks yea the forum I read with the guy doing it early morning used like a .003 gauge instead of the .007 in and .009 ex
Old 04-10-2012, 08:10 PM   #12 (permalink)
Rep Power: 2 JGTC-EG will become famous soon enoughJGTC-EG will become famous soon enoughJGTC-EG will become famous soon enough
Care to share that link?
It is best to stick with the .007" intake .009" exhaust, as the engine warms up the lash is reduced by metal expansion to just where it needs to be.
JGTC-EG
Originally Posted by Eg6-Saechao View Post
i was thinking about the meth i might go that route imma look more into meth see the pros and cons of the meth for me
JGTC-EG is offline   Reply With Quote
Old 04-10-2012, 08:50 PM   #13 (permalink)
Ok sorry about the confusion I looked back at the video and he is actually using .010 in and .013 on exhaust also on second look it was a accord he was working don't know why it popped up when I searched for civic cause the site just says Honda valves soo my mistake sorry guys.. But thanks for responding on engine temp.
Old 04-10-2012, 10:26 PM   #14 (permalink)
theBEST's Avatar
Rep Power: 3 theBEST is nobody
valve adjustment should only be performed when the engine is cold..it DOES matter if the engine has been ran and what spec. u set the clearances to
on a d16z6 u got the specs correctly and set em to that and please make sure the 10mm valve adjusting nut is properly torqued as well and while ur there u mite as well replace the valve cover gasket and spark plug tube seals
theBEST is offline   Reply With Quote
Old 04-11-2012, 08:49 AM   #15 (permalink)
Thanks yea learned that the hard way let my car sit for about 2 hours and adjusted them and got a pretty good tic now lol all well it is now morning and we are going out for round two lol thanks for all the help guys..
iconAll times are GMT -8. The time now is 01:17 AM. | Welcome to Forum, please register to access all of our features.
