Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » DOHC ZC
Old 07-22-2010, 03:54 PM   #1 (permalink)
built zc's Avatar
Rep Power: 2 built zc is nobody
Default Bisimoto cams stock ecu question..
I just finish building my dohc zc motor with stage 1.2 bisimoto turbo cams....I Need to brake the motor in so can I use my stock ecu with them cams??? I was going to brake the motor in before I get it tune ??
built zc is offline   Reply With Quote
Old 07-22-2010, 03:57 PM   #2 (permalink)
mindless's Avatar
Rep Power: 34 mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !mindless is on a level you can only DREAM about! ! !
Use your stock cams to break the engine in.
www.teamdohc.org
Oh noez a chat thread (sign up and join in):http://teamdohc.org/forums/index.php?topic=1428.0
Originally Posted by 99EJ6T View Post
Originally Posted by Dweezil View Post
mindless is offline   Reply With Quote
Old 07-22-2010, 05:21 PM   #3 (permalink)
built zc's Avatar
I sent my stock cams in to bisimoto to get regrind so I don't really have money to get use stock ones..so can i use my stock ecu and my cams to brake my motor in??? Please let me kno I wanna brake my motor in?
Old 07-22-2010, 05:23 PM   #4 (permalink)
Full_Tilt's Avatar
Rep Power: 2 Full_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagleFull_Tilt is fly like an eagle
No, its going to run like dog shit, and its going to be lean at WOT in the upper RPM range. Youre going to need to go WOT and rev it out a lil to break it in properly.
I reject your reality and substitute my own.
Full_Tilt is online now   Reply With Quote
Old 07-22-2010, 05:48 PM   #5 (permalink)
built zc's Avatar
May I ask to what wot is?
Old 07-22-2010, 05:54 PM   #6 (permalink)
Full_Tilt's Avatar
oh sorry,
WOT- Wide Open Throttle
Basically, what I would do is have a street tuner there to do intial tuning as you break in.
Do you first start up with a basemap on it and with the tuner all setup. Once started have your tuner immediatly get to work getting the idle sorta decent, then quickly go out and start breaking it in while he tunes. The initial break in is very fast, so you could probably go ahead and change the oil after the break in and continue tuning.
It would only take a few hours and you would have a healthy broken in engine with a pretty decent street tune on it (if the tuner is any good)
Old 07-22-2010, 07:43 PM   #7 (permalink)
built zc's Avatar
i thought break in is about 500miles????and i have a pr4 ecu thats tune on crome on 5psi can i use that????????????
Old 07-22-2010, 07:53 PM   #8 (permalink)
cticknor666's Avatar
Rep Power: 7 cticknor666 smells like Boratcticknor666 smells like Boratcticknor666 smells like Boratcticknor666 smells like Boratcticknor666 smells like Boratcticknor666 smells like Borat
people still break in their motors? lol
I do all the breaking in, on the dyno while tuning.
cticknor666 is offline   Reply With Quote
Old 07-22-2010, 07:57 PM   #9 (permalink)
Wes
Wes's Avatar
Rep Power: 1 Wes is starting to learn the ropesWes is starting to learn the ropesWes is starting to learn the ropesWes is starting to learn the ropesWes is starting to learn the ropesWes is starting to learn the ropesWes is starting to learn the ropes
I don't understand how you can brake in the motor. I sit in the driver's seat while braking.
Turn on, Tune in, and Drop out
Y7 four-door 98' Civic
GSR 97' Civic coupe
Wes is offline   Reply With Quote
Old 07-22-2010, 10:53 PM   #10 (permalink)
Full_Tilt's Avatar
never heard of engine braking?
lulz
you can also brake with your exhaust, so Ive heard.
more like 5 miles...
and I suppose you "could"
but you should really do what I said, or tow it to the dyno and do what that other dude said
Old 07-23-2010, 01:03 AM   #11 (permalink)
built zc's Avatar
I don't mean brake your motor..I mean when u have a fresh built don't u have to brake your engine in??? And can I use my bisimoto cams with my stock ecu just for braking the engine in ?
Old 07-23-2010, 09:51 AM   #12 (permalink)
Full_Tilt's Avatar
Youre completely ignoring what I said.
YES you have to break your engine in. It takes less than an hour.
Start it up, get it up to temperature with casual driving then go pull vacuum on the rings by accelerating and decelerating in gear, each time increasing rpm. come home, change the oil. Then go beat on the car with fresh oil and a fairly conservative max rpm.
Old 07-23-2010, 10:01 AM   #13 (permalink)
6262 > Holset
danz's Avatar
Rep Power: 21 danz Still a JDM Star....
danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....danz Still a JDM Star....
turbo 1.2 cams are MILD.
you will be A-OK on a stock ECU
my EJ6 build thread here!
2010 - 11.225@120.82mph - Z6
2009 - 10.912@127.33mph - A6
Special thanks to ColtCams.com and Go-Autoworks.com!
danz is offline   Reply With Quote
Old 07-23-2010, 02:16 PM   #14 (permalink)
Rep Power: 7 The_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatnessThe_Acid_Beaver is approaching greatness
It will run richer than normal, but not excessively. The stock ECU will be more than up to the task.
Pull the ECU fuse, crank the engine over in short spurts until the oil light goes out. Put the fuse back in. Start it up. Let it warm up. Check for leaks, listen for nasty noises. Set ignition timing (correctly). Drain oil, change filter. Replace oil and filter. Drive the car in 1-2-3, putting load on the engine. For example get going to 20MPH, put it in third, then stomp on the gas pedal, until you hit about 3500RPM. Let off the gas. Do this a few more times. Do not drive at constant speeds in one gear. The rings must seat quickly.
After doing this for a while, you should notice less smoke, better power, and no issues. If there are no issues, drive it like you stole it. Change the oil to whatever you want at 500 miles and put a new filter on.
Done.
My quench is tighter than yours! :P
#1 P29 hater.
The_Acid_Beaver is offline   Reply With Quote
Old 07-23-2010, 09:22 PM   #15 (permalink)
built zc's Avatar
Ok thanks.... is there a certain way to time my 1.2 turbo cams??or do I time them as same as stock?
Old 07-23-2010, 09:38 PM   #16 (permalink)
Time it like stock.
Old 07-26-2010, 09:23 AM   #17 (permalink)
randull's Avatar
Rep Power: 0 randull is nobody
You should be completely fine with your stock ECU. But keep in mind to extract maximum power and reliability you need to tune it. If you have any other questions or concerns shoot me an email and I will get you squared away:
Randy@Bisimoto.com
randull is offline   Reply With Quote
Old 08-04-2010, 11:33 AM   #18 (permalink)
built zc's Avatar
Thanks people
iconAll times are GMT -8. The time now is 06:46 PM. | Welcome to Forum, please register to access all of our features.
