Need help on timing my dohc zc motor???? - D-series.org
Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » DOHC ZC
Old 02-06-2009, 06:44 PM   #1 (permalink)
built zc's Avatar
Rep Power: 0 built zc won't last long at this rate
Default Need help on timing my dohc zc motor????
i need to time my dohc zc motor but not sure how to time the motor????need step by step instruction on how to time my motor???thanks for the help??
built zc is offline   Reply With Quote
Old 02-06-2009, 08:25 PM   #2 (permalink)
The_Acid_Beaver's Avatar
Rep Power: 19 The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!
The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!The_Acid_Beaver is the fucking MAN!!!!
ZOMGWTF?
1. Get a manual.
2. Open Manual.
3. Find Timing belt section in manual.
4. Read how to change timing belt.
5. Follow directions in the manual.
6. Congratulate self on a job well done.
7. Consume refreshing beverage of choice.
Don't ()*#$(*$ PM me unless I ask you to.
How To Tune OBD0 with TurboEdit
My fab blog.
The_Acid_Beaver is online now   Reply With Quote
Old 02-07-2009, 09:33 AM   #3 (permalink)
qweakers's Avatar
Rep Power: 6 qweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regularqweakers is obviously a regular
here i'll spoon feed you a little
http://www.thezcr.com/forums/local_links.php?catid=3
90 crx dx no heart
88 crx dx (future drag whore)
88 crx si (stock)
88 crx si y-49
93 ACURA INTEGRA LS
93 civic cx, poor mans type r, stroked, jrsc (coming soon)
qweakers is offline   Reply With Quote
Old 02-10-2009, 06:34 AM   #4 (permalink)
delslowZC's Avatar
Rep Power: 5 delslowZC is almost a somebodydelslowZC is almost a somebodydelslowZC is almost a somebodydelslowZC is almost a somebody
these are instructions to put the belt back on. i am assuming you got this far.
you just make sure that your cam timing marks are facing each other perfectly. the have to be perfectly horizontal, this requires you to hold the cams with wrenches while you put the belt back on.
the crank timing mark needs to line up with the notch on the block.
than you put your belt back on.
then you turn the whole thing three teeth by putting a big wrench or ratchet on the crank. you turn it counter clockwise. this puts tension on the belt.
then tighten the bolt on the timing belt tensioner.
then start it up. hopefully you got the timing right, otherwise you could mess it up pretty good.
My del Sol ZC Turbo Build Thread
xbox live gamertag im2snug4urButt
delslowZC is offline   Reply With Quote
Old 02-11-2009, 11:13 AM   #5 (permalink)
built zc's Avatar
thanks delslowzc your the only one that made the instructions really clear to me thanks again man????yea i followed everything you said and it turned out good thanks!!!
Old 02-11-2009, 12:41 PM   #6 (permalink)
delslowZC's Avatar
no prob, just lookin out and now you know.. what's up on a + rep lol
iconAll times are GMT -8. The time now is 01:48 PM. | Welcome to Forum, please register to access all of our features.
