This might not be the best way, but it easily gets the job done!
Tools and Items Required -Drill with ~1/8" drill bit -New hardware -Multi-Meter for calibration Heres what your working with- (On the Left is a GSR, on the Right is a B16a1. ![]() ![]() Step 1, start drilling on the center of the rivet head and work it around until it breaks off. Notice: Don't apply too much pressure to the drill, especially when your turning the bit. It will either 1- screw up your drill bit and/or 2- screw up the product your working on if it slips off. ![]() ![]() Step 2, Carefully pull it off and transfer gaskets(or better yet replace it with a new one) Note: If you need to, you can remove the studs left over by the drilling (B16a1 TB) by simply spraying some Deep Creep or PB Blaster onto the studs, clamping some vice-grips onto them, and work them loose. ![]() ![]() Step 3, slip the TPS onto the "new" throttle body, in this case, the GSR. Find the appropriate hardware (they are a little smaller than standard 10mm machine screws. I don't know the size) and snug it down. ![]() ![]() Calibration of the TPS: 1.)You will need a volt meter set to read 12 volts. 2.)Loosen the screws holding the TPS to the throttle body enough to rotate the sensor a bit. 3.)Insert the probes of your voltmeter onto the wires leading to the TPS. One of the outer wires, and one to the center wire (the center wire is the output wire, where you will recieve your voltage reading; Typically red/blk) If you just measure the two outer wires, it will show 5v on your voltmeter. 4.)With the ignition on, but the engine not running you should read less than 1 volt with the throttle shut. Rotate the sensor until your volt meter reads .5 volts. 5.) Once you read .5 volts tighten the screws holding the TPS to the throttle body. 6.)Voltage should go from .5 volts closed up to approximately 4.8v volts at wide open. 7.)Once you have these readings your TPS is properly calibrated. Hope this helps someone Thanks for looking! -Andrew Last edited by Andrew; 05-22-2008 at 03:08 AM. |
#4 (permalink) | |
D-series.org Sponsor
Nice DIY write up
D-Series.Org Sponsor...check our feedback ![]() ![]() Shop 24/7 @ WWW.GO-AUTOWORKS-STORE.COM 88' Civic D16 10.9@136MPH Thanks D-Series.ORG for all of the continued support! Thanks to our Race Sponsors Innovative Mounts, SPEC Clutch, & Bullseye Power 2009'-2010' Import Face-Off Title Sponsors...Keep the Sport alive, Come Race with US!! [ |
#5 (permalink) |
Don't forget that you still need to calibrate the sensor to the TB after you install it
My CarDomains: http://www.cardomain.com/ride/633410 http://www.cardomain.com/ride/2771244 |
#7 (permalink) |
nice work dude
i hear my turbo spooling ....wait thats just my credit car getting charge ...]]RIP sohc turbo 250 dd 99redek sneek attack :noway:go faster than fast.... EK single slam SOLD EJ1 coupe Dx sold.... ROCKING DC2 R I'm PayPal Verified |
#9 (permalink) | |
Here NOOBIE, NOOBIE
nice write up
![]() Quote:
DIY IACV Cleaning My For Sale Thread
#10 (permalink) |
Good stuff, Andrew!
88 CRX DX - RIP ??.2007 90 Civic EX - RIP 9.14.2009 92 Civic CX - RIP 4.10.2010 97 Civic EX - 4th Times the Charm...? JS7 Racing · TallyImports.com · BFH Customs |
#14 (permalink) |
thats what i have done every time.
1993 D16Z6 Civic Turbo 230hp 218tq 1996 Acura Integra LS Sedan 1994 Civic DX "going to a good home" Laying Claim To My Own Thread:http://www.d-series.org/forums//showthread.php?t=17947 1996 Integra Project Car:http://www.d-series.org/forums/showcase/72073-1996-integra-ls-sedan-pics-6-22-10-jdm-front-5-lug-auto-manual.html 1994 Civic DX Project Super Beater:http://www.d-series.org/forums/showc...ml#post1890018 Autoworks Import Buildershttp://www.go-autoworks.com/
#15 (permalink) |
wanna touch my sock monkey
nice very nice rep for joo.
1 monkey power = 0.332 hp. The suspension should always be faster than the engine - BMW The term stage was created to make mentally slow ppl fell physically fast. my DOHC ZC - 115.76whp and 97.13wtq (untuned) |
#16 (permalink) |
good stuff
Build what you got... 91' CRX Si All motor A6 running 14.67@93.87mph. My build: http://d-series.org/forums/engine-bu...n-rebuild.html For sale thread: http://d-series.org/forums/sale/1090...arts-sale.html PS3 Modern Warfare 2 gamer tag: Black91CRX |
#17 (permalink) |
How a bout a pic of the two wires that need to be tested? And how do you test them when they're connected to the TPS?
http://card.mygamercard.net/sig/SheldonR311.png My Fleet: 1995 Honda Del Sol Si D16Z6 1993 Volkswagen Passat VR6 (Swap Car) 1990 Volkswagen Corrado G60 (Rocket Queen) 1989 Volkswagen Jetta Coupe VR6 (Grey Goose) 1985 Chevy C-10 Pickup 2wd 3-speed w/overdrive on the floor |
#19 (permalink) |
If you have a chipped ECU then there is another real good way to calibrate. Hook up a laptop to the datalogging port and calibrate via TP on the datalogging software. Great way to see if your getting WOT too, b/c mine was juuuust over 90% when it was closed at 0%.
http://i36.photobucket.com/albums/e1.../Signiture.jpg |
#20 (permalink) | |
EDIT: which sucks by the way.
Suga Rashad Evans! Last edited by guest; 05-05-2009 at 07:35 PM. |
