DIY: Super-Bright Parking Light Mod. *pics* - D-series.org
Go Back   D-series.org » D-series Knowledge Factory » DIY Forum
Old 06-20-2005, 10:01 PM   #1 (permalink)
peace out
icarusdown's Avatar
Rep Power: 10 icarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatnessicarusdown is approaching greatness
Default DIY: Super-Bright Parking Light Mod. *pics*
you get nothing!
icarusdown is offline   Reply With Quote
Old 06-20-2005, 11:03 PM   #2 (permalink)
makku's Avatar
Rep Power: 14 makku is a Top Aussie
makku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussiemakku is a Top Aussie
912 bulb = 11.6 watts at 12V = .967 Amps of current
194 bulb = 0.27 or 0.33 amps (depending on what style you use)
The fuse connected to that system (at least in 92-95 civics) is 10 Amps. If you put all 4 in, be careful...
Minimum wire gauge for 1 Amp applications is 24 gauge for copper wire. This is based on permissible voltage drop, not wire heat-up. You could probably go a little thinner and be ok still. But remember where the wire carries current for all signals... that has to be able to handle the 4 Amps you'll need to power all 4 corners. 18 gauge is recommended for minimum voltage drop. Again, you can go a little thinner since we're not talking audio here...
yeah, I guess you're ok with these bulbs.
i just checked... 92-95 corner marker bulbs are about 2 Amps! so you should be ok if your wiring is thick enough.
My car: 94 Civic DX sedan w/ JDM D15B VTEC
Trustworthy people: krAzySi, thesqad127, Turntune, Civic4ges, Sonny7730, mark7901, miked16z6, Low EG-T
http://www.d-series.org/forums/attac...1&d=1141771732
forecast for tomorrow... a few sprinkles of genius with a chance for DOOM!
But I thought you said TV was bad?
It is... but we fucking need it.
makku is offline   Reply With Quote
iconAll times are GMT -8. The time now is 01:55 PM. | Welcome to Forum, please register to access all of our features.
