DIY del sol seats in Civic - D-series.org
LinkBack (1) Thread Tools Display Modes
Old 12-26-2008, 12:00 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
HCivicdx's Avatar
Rep Power: 9 HCivicdx is learning the way of the DHCivicdx is learning the way of the D
Thumbs up DIY del sol seats in Civic
ok so i have decided to make a DIY del sol seats into any other car thread because i have been asked many times how did i get the seats to bolt up
so here is the seat i found it at a local junkyard and was lucky because the car just came into the yard the day before it even still had the ecu in it...make sure that you clean the seat before doing anything to it with some soap and water...
to start off you need to remove the old seat.
then after you have removed the old seat you need to take the rails off of it and that involves numerous things
1. remove the plastic coverings on the side of the seat
2. you need to remove one rail first for the next step (there are 3 10 mili bolts, the bolt on the back of the seat will be the toughest to remove)
3. there is a metal wire under the seat that connects the two rails together for when the seat slides front to back...once you have removed that one rail then this wire can be removed (make sure not to lose the washers on the wire)
4. once you have removed the wire proceed to remove the next rail (it also has 3 10 mili bolts)
5. be sure not to lose the wires or bolts because you will need to reuse them
The two rails above one is from the civic (top) and the other is from the del sol (bottom) which you can see that the are different from one another.
Now that you have removed the rails from the civic and del sol seat be sure no to mix them up also do not mix the hardware up
Now i have chosen to paint the fabric with fabric paint before i install it and that reqiures you to take the seat completely apart...make sure you let it completely dry (overnight)
Now once you are done with painting and putting the rails on the del sol seat it is ready to bolt right in
If you have any questions just fee free to ask and the passenger side is the same process...i have also installed the passenger seat...
Quote: Dude it's a honda...it's like a god....you never talk bad about it....
HCivicdx is offline   Reply With Quote Quick reply to this message
Old 12-26-2008, 02:40 PM   #2 (permalink)
wheres my money man!!
sleepingciv's Avatar
Rep Power: 40 sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !sleepingciv is on a level you can only DREAM about! ! !
iTrader Score: 143 reviews
when i had my 95 eg the sol seats i used bolted right in are the hatches different?
what year is your car what year are the sol seats??
PM me for
also do tucked harnesses
sleepingciv is offline   Reply With Quote Quick reply to this message
Old 12-27-2008, 03:07 PM   #3 (permalink)
Rep Power: 11 snail89 is nobody
well what i did with my i just soldered into my rex with out swapping nothing
snail89 is offline   Reply With Quote Quick reply to this message
Old 12-27-2008, 03:14 PM   #4 (permalink)
Asshole
Chrisfrom1986's Avatar
Rep Power: 45 Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !Chrisfrom1986 is on a level you can only DREAM about! ! !
iTrader Score: 41 reviews
94 sol seats bolted into the 93 hatch no problems.
94 rs nh-575M Thunder Gray Metallic - Non-op
93 dx bg-29p Aztec Green Pearl - Non-op
94 Infiniti J30T
96 ex ??-?? Something Silver - flip project
Chrisfrom1986 is online now   Reply With Quote Quick reply to this message
Old 12-27-2008, 09:24 PM   #5 (permalink)
STUNNA Aaron's Avatar
Rep Power: 0 STUNNA Aaron is nobody
Lol soldered???? Or you mean welded?
Lol....
STUNNA Aaron is offline   Reply With Quote Quick reply to this message
Old 12-27-2008, 09:31 PM   #6 (permalink)
BiggieBert's Avatar
Rep Power: 22 BiggieBert Still a JDM Star....
BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....BiggieBert Still a JDM Star....
iTrader Score: 12 reviews
LOL^
you will get stuck in the "willfully ignorant" category and I will do what I can to see that you never get an answer to any question you ever ask on this forum again.
BiggieBert is offline   Reply With Quote Quick reply to this message
Old 12-27-2008, 10:07 PM   #7 (permalink)
HCivicdx's Avatar
Well I got my seats out of a 94 del sol and I had to swap the rails and everyone else that I have come across has had to swap the rails to have them fit and it also depends on the car too
Old 12-28-2008, 08:18 AM   #8 (permalink)
mmmmm sexy bay
jimmyb34's Avatar
Rep Power: 50 jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !jimmyb34 is on a level you can only DREAM about! ! !
iTrader Score: 29 reviews
not sure what year sol my seats came out of but they bolted into my 93 cx perfectly...
jimmyb34 is offline   Reply With Quote Quick reply to this message
Old 12-28-2008, 08:25 AM   #9 (permalink)
boostfreak0885's Avatar
Rep Power: 18 boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
boostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcanoboostfreak0885 is hot as a volcano
lol i sure hope he meant welded, shit i did a nice pull one day, and the passanger seat where my buddy was sitting broke... and that was a factory seat/rail..
my new and improved build... check it out
best time so far
11.201 at 128mph with a 1.79 60 foot.. damn i need traction, best trap speed is 129mph. 26psi h1c
NEW best 60' 1.56!!!
boostfreak0885 is offline   Reply With Quote Quick reply to this message
Old 12-28-2008, 06:10 PM   #10 (permalink)
Rep Power: 101 transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !transzex is on a level you can only DREAM about! ! !
sol seats HAVE to have the seat rails swapped before they will bolt into a EG.
Jimmy and others, you likely bought the Sol seats that had already been converted.
I know it is VERY likely someone on here from OH or WV has the ones I converted, gray stripes.
Old 12-28-2008, 06:29 PM   #11 (permalink)
HCivicdx's Avatar
Thank you transzex for clearing that up
Old 12-28-2008, 09:17 PM   #12 (permalink)
Taztwnpa's Avatar
Rep Power: 9 Taztwnpa will become famous soon enoughTaztwnpa will become famous soon enoughTaztwnpa will become famous soon enough
Nice write up. What is the avantage of the del sol seats?
Taztwnpa is offline   Reply With Quote Quick reply to this message
Old 12-28-2008, 09:45 PM   #13 (permalink)
mmmmm sexy bay
jimmyb34's Avatar
mine came from texas.. out of a del sol... lol
Old 12-28-2008, 10:42 PM   #14 (permalink)
Asshole
They look a lot nicer than civic seats and are more comfortable. My friend just informed me that he only used 3 of the 4 mounting holes, and slotted one of the 3 to bolt them in.
94 Infiniti J30T
Old 12-28-2008, 11:27 PM   #15 (permalink)
I took mine from a 94 sol in the junk yard and bolted right in my 95 coupe
PM me for
Old 01-03-2009, 07:09 AM   #16 (permalink)
Rep Power: 9 tuner4life is nobody
Done that many times nice write up
tuner4life is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 09:07 AM   #17 (permalink)
cmgreen50's Avatar
Rep Power: 20 cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!cmgreen50 is the fucking MAN!!!!
you oversprayed the red stripe with your fabric pain... still looks good though
i seriously have a donkey if you're serious..
The problem is, my need for speed exceeds the need to save the earth.
WELL FINE! I'LL JUST GO EAT THE SHIT OUTTA MY OREO'S THEN!
cmgreen50 is offline   Reply With Quote Quick reply to this message
Old 02-03-2013, 09:25 PM   #18 (permalink)
jhuerto23's Avatar
Rep Power: 0 jhuerto23 is nobody
I just picked up a set of del sol seats, I am not sure what year they're from but they did not bolt right on into my 94 civic hb cx. I had to swap out the rails to make it fit.
slow n easy
keepinitclean
jhuerto23 is offline   Reply With Quote Quick reply to this message
Old 02-05-2013, 04:51 AM   #19 (permalink)
EJ6Civic27's Avatar
Rep Power: 12 EJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to allEJ6Civic27 is a name known to all
iTrader Score: 17 reviews
Bumping an old ass thread...but...
It doesn't matter what year the del Sol was. ALL del Sols are identical, chassis wise. The only differences are the trims. S, Si, and VTEC. A 93 del Sol seat will bolt into a 97 del Sol. I don't know why everyone keeps asking what year the del Sol was that their seat came out of...
a6 Cam/z6 intake manifold/full header back exhaust
Spider RPM tune/3500rpm launch/7200 fuel cut/NGK AFX Wideband
EJ6Civic27 is offline   Reply With Quote Quick reply to this message
Old 02-05-2013, 05:53 AM   #20 (permalink)
NaveLB's Avatar
Rep Power: 0 NaveLB is trying to make new friends
This right here is correct and I know this for a fact cause I've done this countless times.
1994 Honda del Sol Si-sleeved d16z6
DO NOT GET WORK DONE BY JG ENGINE DYNAMICS
NaveLB is offline   Reply With Quote Quick reply to this message
LinkBacks (?)
LinkBack to this Thread: http://www.d-series.org/forums/diy-forum/102993-diy-del-sol-seats-civic.html
Posted By For Type Date
Delsol seter inn i ej6 coupe. This thread Refback 01-20-2013 02:33 AM
iconAll times are GMT -8. The time now is 09:44 PM. | Welcome to Forum, please register to access all of our features.
