Go Back   D-series.org » D-series Knowledge Factory » Audio/Electronics
Old 07-02-2009, 11:52 AM   #1 (permalink)
Rep Power: 1 phillie is trying to make new friends
Default Need some help with Door actuator and shock sensor install
I've got my alarm in. It was previously installed by shop. I want to install door actuators and shock sensor. Anyone do this already? I have an older viper alarm. TIA.
phillie is offline   Reply With Quote
Old 07-02-2009, 11:54 AM   #2 (permalink)
Deal with it...
Bizzar's Avatar
Rep Power: 50 Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!
Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!Bizzar is the fucking MAN!!!!
Ok, so what's your question? Mounting? wiring? Relays?
16.5 psi full interior run
7.80 @ 88mph 1/8 mile.
297 Mustang Dyno whp @ 20psi
Bizzar is online now   Reply With Quote
Old 07-02-2009, 12:00 PM   #3 (permalink)
I was in a hurry and forgot to specify. Will I need 2 relays? One for each door and is it better to get the relay with the suppression diode? Where do you tap into for 12v constant for the relay. I don't have power doors so I have to do all the wiring. As for the shock sensor, where are they usually mounted. Thanks
Old 07-02-2009, 12:01 PM   #4 (permalink)
Pata's Avatar
Rep Power: 17 Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!
Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!Pata is the fucking MAN!!!!
does that Old Viper Alarm come with a Trunk Release Feature? (i think it does)
It should be a Gray Wire. Wire that to a Relay and the Relay out goes to the Actuator.
Does that make sense?
The Shock sensor is usually tied to the steering column or somewhere under the Dash.
Originally Posted by E. Jeezy View Post
My name is E. Jeezy and I approve of hating on haters that hate on the Y7.
Originally Posted by mindless View Post
Ask any racer, any real racer: doesn't matter if you own a coupe or a hatch....sedans fuck your mother.
My For Sale Thread
Pata is offline   Reply With Quote
Old 07-02-2009, 12:06 PM   #5 (permalink)
Deal with it...
Bizzar's Avatar
You need 2 relays for the door actuators. 1 for unlock, the other for lock. Here's a basic wiring diagram for you.
http://documents.audiovox.com/701139.pdf
edit: That pic is kinda poor. I tie my grounds together and my powers together. Basically just jump them over from one relay to the other. Just tie in the second actuator wiring as it only pictures one. Sort of like this:
Need adobe to read it duh. As for where to tap for power, use the ign harness. There's an 8ga constant wire that can handle the current draw. I like to mount the door lock relays in the kick or just above the kick panel in case one fails.
The shock sensor works best when you mount it to the steering column. Zipties work fine but be sure no wires or the sensor is near any moving parts.
Old 07-02-2009, 12:28 PM   #6 (permalink)
I'll reply when I get back from work. Thanks.
Old 07-02-2009, 06:59 PM   #7 (permalink)
So ill need only 2 relays for both doors. There should be be 2 outputs also right? One to open and one to close? Thanks for the help. I hate havin to use my key.
Old 07-02-2009, 08:00 PM   #8 (permalink)
Deal with it...
Bizzar's Avatar
Well 2 wires to each actuator (4 coming off the relay). They are reversing polarity actuators.
Old 07-02-2009, 08:16 PM   #9 (permalink)
Bizzar forgot to mention great diagram! I meant for the alarm brain. Should it have 2 outputs? One for unlock and one for lock?
Old 07-03-2009, 07:57 AM   #10 (permalink)
Deal with it...
Bizzar's Avatar
ahh yes it should. Its usually a 2 or 3 wire plugin. Green/blue is the most common color.
Old 07-07-2009, 09:42 PM   #11 (permalink)
kaace's Avatar
Rep Power: 4 kaace smells like Boratkaace smells like Boratkaace smells like Boratkaace smells like Boratkaace smells like Boratkaace smells like Borat
make sure and mount that shock sensor with a screw or double stick tape to a solid piece of the car...
and turn the sensitivity down low...
under the center console is a good place to put it...extend the wires if you have to...
Originally Posted by Dmod View Post
So TTTSARBTBTFTTBGITDRIOSWYTBASYPFOIIIAITYATNGYAMCFAI bolts?
Certain pages of this mofo is goddamn rocket science.
Originally Posted by 99EJ6T View Post
lmk when you go back to 1982, i need to slap some one..
just shut your dumb internet face before i call your mom and tell her to come and get you...
kaace is offline   Reply With Quote
Old 07-07-2009, 09:43 PM   #12 (permalink)
kaace's Avatar
model number for the alarm?...find the brain?
Old 07-07-2009, 09:49 PM   #13 (permalink)
Pata's Avatar
Phillie,
Are you trying to put Keyless entry or do you want to shave your Door Handles??
The Answer I gave you was for if you want to put Door Poppers when you shave your Door Handles lol
This is Simple. Just buy yourself a Keyless entry kit. you might have to walk around with 2 remotes tho
My For Sale Thread
Old 07-19-2009, 12:51 AM   #14 (permalink)
I have to look again but I think it was something like a 250-350 esp?
Originally Posted by Pata View Post
Phillie,
I'm not trying to shave my door handles. The 93 si's didn't come with electric door locks. I just want to add actuators so I don't have to use the key to open the doors. So when I dis arm the alarm the door locks open and visa versa. I think that diagram should work though. All thats left after that is the shock sensor and add a horn relay so when the alarm goes off the horn does too.
iconAll times are GMT -8. The time now is 07:35 AM. | Welcome to Forum, please register to access all of our features.
