Go Back   D-series.org » Motor Mayhem & Suspension Satisfaction » 7th Gen
Old 05-29-2007, 11:47 AM   #1 (permalink)
wetdrt's Avatar
Rep Power: 0 wetdrt is nobody
Default Injectors??
if rsx injetors work in the d17 will after market rsx injectors work as well?
found some for cheap but need to know b4 buying.
wetdrt is offline   Reply With Quote
Old 05-29-2007, 11:56 AM   #2 (permalink)
I got a promoted! And I'm PINK!!
Green 91's Avatar
Rep Power: 4 Green 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regularGreen 91 is obviously a regular
nope, SRT4 ones will. but you will need to modify teh fuel rail
andy other injector then stock, the fuel rail needs modified.
RDX injectors will work, RSX Type S.
my bro runs SRT4 570cc injectors on his d17a2
Green 91 is offline   Reply With Quote
Old 05-29-2007, 12:16 PM   #3 (permalink)
wetdrt's Avatar
any srt-4 brand or just stock srt-4 injectors? and how big are srt-4 stock injetors?
Old 05-29-2007, 12:21 PM   #4 (permalink)
Green 91's Avatar
my bro used the stock SRT4 injectors.
570cc
aftermaket injectors wont work on D17s because they will hit the TPS sensor
Old 05-29-2007, 12:25 PM   #5 (permalink)
wetdrt's Avatar
cool thx a lot
Old 05-29-2007, 12:47 PM   #6 (permalink)
wetdrt's Avatar
what did he do to get them to work on the car? it wasnt plug and play was it?
Old 05-29-2007, 12:56 PM   #7 (permalink)
Green 91's Avatar
he runs emanage, hes boosted.
you would need injector clips to fit them.
but RSX type S stock injectors(310cc)s are plug and play, except for raising the rail, need longer bolts/studs
Old 05-29-2007, 05:16 PM   #8 (permalink)
Rep Power: 5 buds302 is nobody
you do the same modifications as you would for the rsx injectors to make the SRT4 ones work. all you need to do is get longer studs to bolt down the rail. both RSX-S and SRT4 injectors are the same dimensions. any other aftermarket fuel injectors available for the RSX type S will not work. they are longer and will hit the TPS sensor. i run Emanage with my injectors andit was plug n play. you need to get it tuned tho. you will have some slight idle issues.
PS. the RSX injectors are 310cc
and the SRT4 injectors are 570cc
i used older srt4 injectors. they were in the STG1 kit available from mopar. newer SRT4 injectors...04-05 came stock with them
buds302 is offline   Reply With Quote
Old 05-29-2007, 05:18 PM   #9 (permalink)
Green 91's Avatar
you have idle issues because the maps weren't changed for the 570ccs
Old 05-29-2007, 05:21 PM   #10 (permalink)
actually they were
Old 05-29-2007, 09:21 PM   #11 (permalink)
wikkaco0's Avatar
Rep Power: 4 wikkaco0 is nobody
Do you know if the RDX injectors the same dimensions as the RSX-S ones?
Any longer and it looks like the fuel rail will run into the throttle body.
wikkaco0 is offline   Reply With Quote
Old 05-29-2007, 09:31 PM   #12 (permalink)
Green 91's Avatar
i belive there the same dimentions.
my bro almost bought some
Old 05-29-2007, 10:22 PM   #13 (permalink)
speedfoos's Avatar
Rep Power: 10 speedfoos is hot as a volcano
speedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcanospeedfoos is hot as a volcano
^^^ Agreed, a few folks have found the RDX work in 7th gens as well. No personal experience on this though. Just other posts.
I hate Cash for Clunkers.
2008 Lexus IS250
2004 Nissan Frontier "Super Bunny"
1966 Volvo Amazon "Lucille" - 383 Stroker Build!!!
speedfoos is offline   Reply With Quote
Old 05-30-2007, 09:29 AM   #14 (permalink)
wikkaco0's Avatar
Well I've heard alot of people using them in K series motors. Never seen a set in a D series. But at 50$ per new injector from an Acura dealer (Honda can't get them), it's much better than 200$ per injector from the RSX-S. I'm going to be picking up a set before the end of summer.
Also, Toyota injector clips with part number 90980-11875 are supposed to fit for the wiring.
Old 05-30-2007, 09:36 AM   #15 (permalink)
Green 91's Avatar
$200 per injector?!
my bro go all his i belive for less that that
Old 05-30-2007, 10:47 AM   #16 (permalink)
i paid 35 bux for my rsx injectors
i paid 45 for my SRT4 ones
the Rdx injectors will fit just like the typeS ones and the SRTones but the connector needs to be trimmed. it will plug right in but needs to be trimmed down a little
Old 05-30-2007, 12:41 PM   #17 (permalink)
wikkaco0's Avatar
That's what I got quoted at a local Acura dealership. It's also in Canadian dollars.
Old 05-30-2007, 12:50 PM   #18 (permalink)
speedfoos's Avatar
Get those bad boys used from either Ebay, a junkyard, or another member. The stealership is way to expensive for those types of parts.
2008 Lexus IS250
Old 05-30-2007, 02:23 PM   #19 (permalink)
wikkaco0's Avatar
Yeah no kidding eh. But I'm going to get the RDX ones new. At 50bux a piece, I don't mind. Plus, new injectors don't come dirty and with gunk on it.
Old 05-30-2007, 02:24 PM   #20 (permalink)
wetdrt's Avatar
what do you mean maps? map sensor feul map or what?
HTML code is On
iconAll times are GMT -8. The time now is 07:34 AM. | Welcome to Forum, please register to access all of our features.
